Octane Question
Old Sep 9, 2005 | 12:26 AM
IMA 66's Avatar
IMA 66
Default Octane Question
So i went to fill up at Sunoco today clicked on high test and it was like regular is all we have. So i filled the 74 up with 87 MY question is this, will it really make any difference? I mean it is an l48 with a whopping what 8.5:1 compression ratio I did notice tonight on the way home that the car did seem to stink a little more then usual but that was it. I did get into it and din't hear any pinging all though it was cool out.
Old Sep 9, 2005 | 12:56 AM
colorado1967's Avatar
colorado1967
Unless you have increased the original 8.5 or even 9.0 engine comp you don't need high test. Saves money and prevents carbon build up which can happen with low compression engines using high test.
Old Sep 9, 2005 | 01:36 AM
Mefixum's Avatar
Mefixum
Cruising
I'm no expert in fuel here, but my 79 runs fine on low octane too. Don't get me wrong I love to treat her to good fuel though, the big 93! Yeah!
Old Sep 9, 2005 | 02:44 AM
LiveandLetDrive's Avatar
LiveandLetDrive
a worn out engine will be more likely to ping but otherwise you're good with the lower compression. Weird that they'd run out of premium.
Old Sep 9, 2005 | 03:37 AM
WhichVette?'s Avatar
WhichVette?
Most engines below about 10:1 or so don't need premium. Just wasting your money...
Old Sep 9, 2005 | 07:52 AM
Mike Ward's Avatar
Mike Ward
All '74s were designed to run on regular gas right from the factory. There is no benefit whatsoever in running higher octane than that. Think of the thousands of dollars that people waste by buying high octane gas.
Old Sep 9, 2005 | 09:12 AM
sxr6's Avatar
sxr6
"All '74s were designed to run on regular gas right from the factory. There is no benefit whatsoever in running higher octane than that. Think of the thousands of dollars that people waste by buying high octane gas. "
X2
All "high test" does is provide a more controlled burn (so you can run more ignition & compression). It is actually a slower burning fuel than reg. Unless your car requires it please just send me your extra cash, I have a better use for it
Old Sep 9, 2005 | 09:44 AM
any4xx's Avatar
any4xx
Don't forget that you will get the BEST performance from the LOWEST octane rated fuel that your car can safely use. Using higher octane rated fuel than is necessary not only wastes your money, but actually LOWERS your performance!!!
Old Sep 9, 2005 | 10:14 AM
mooneyd's Avatar
mooneyd
He's right
Old Sep 9, 2005 | 12:29 PM
rihwoods's Avatar
rihwoods
Seems all we can get is 91..89..87 here...my 78 is 8.9:1 and the beast is 9.6:1.....interesting about low compression vice 91 + octane...have to think about that one..in the meantime,the beast will get 91 Chevron...
Rich
Old Sep 9, 2005 | 06:20 PM
sjr1971's Avatar
sjr1971
GM saw this comming. My '71 owners manual for an LS5 454 , 8.5:1 comp. recommends 91 Octane. I don't have to go to an airport for gas
Remember when there WAS such a thing as 'cheap' stuff ?
Old Sep 9, 2005 | 09:13 PM
StickShiftCorvette's Avatar
StickShiftCorvette
I think the 91 recommendation is based on the research octane number, not the current (R+M)/2 , average of research and motor octane numbers. ALL C3s made after '70 ('71 and later) were made to run on regular unleaded gas.
Old Sep 9, 2005 | 09:43 PM
Glass Act's Avatar
Glass Act
From: 406ci SB, AFR 180 Heads - 490 HP @5,600 RPM 529 lb-ft @ 4,100 RPM
My 71 RPO LS6 454-425 HP does not like low octane gas, so she gets noting but high test.
Now my 79 L-82 350-375HP (lots of motor work) runs best with high test also. This one hesitates when it gets reg gas only, as soon as it gets high test it doesn't. For all I drive them in a season, I don't mind the extra cost. I know most here say they will run on reg, I know the differents in sound and reaction when I ask them to Mooove. My 0.2 only.
Old Sep 10, 2005 | 11:00 AM
Mike Ward's Avatar
Mike Ward
Old Sep 10, 2005 | 12:26 PM
Ironcross's Avatar
Ironcross
I too was PO at the price of premiun and dumped some 87 in to my 1966 L72 427 powered 68 Camaro. It seemed to run ok and I thought I was getting away with something. Last night coming home I ran across a friends 40 Ford and we both jumped on it. WRONG thing to do with regular, the SOB rattled like crazy. I guess as long as you are real easy with the go pedal it will get you from point A to B, but dont hammer it. I should have know better too.
Old Sep 10, 2005 | 12:42 PM
Star79's Avatar
Star79
If one was running lots more timing advance than stock (like any of us who tune ala Lars) would that have any effect on pre-ignition/knock using low-grade with low compression (stock-ish 79 L-48)
Old Sep 10, 2005 | 12:56 PM
Ironcross's Avatar
Ironcross
Late 70`s Vettes were low compression and the use of low grade fuels are compatible. As far as advance, you cant put more into the engine than it can use with out having harder starts. The engine itself will almost tell you how much it will take. `
To Octane Question
Old Sep 10, 2005 | 01:55 PM
El_Cid's Avatar
El_Cid
now does this work with all C3s? I run 93 on my stock 82, but if its doing nothing, id like to know.
Old Sep 11, 2005 | 02:37 AM
LS-Five's Avatar
LS-Five
East bound and down...
This is a good point. If you are running more advance than stock, you certainly will notice a difference in how well your car runs depending on the grade of gas you are putting in your car. Also you may have a slightly higher compression ratio than what you think that you have due to carbon build up, if you put a tank of 93 or higher in your tank and your car seems to run better, it may not be just your imagination. Just some food for thought.
Old Sep 11, 2005 | 02:47 AM
LS-Five's Avatar
LS-Five
I am not that familiar with the TBI that those cars use, but I know on late model fuel injected cars your car will run more advance if the computer does not detect spark knock, therefore, if you are running a higher grade of gas you may feel more power. This is especially evident with performance chips and programmers. The increase in most cases wouldn't be worth the extra cost at today's prices though, so I don't advocate running 93 octane in your corolla, but now you know that it can make a difference.
