window troubles
Old Sep 9, 2005 | 03:32 PM
cab's Avatar
cab
Default window troubles
i recently replaced a driver door panel and tunnel insulation where i had to remove the console. now when you hit the electric window button it is hot as a firecracker. what could this be it is a 77. thanks for any help.
Old Sep 9, 2005 | 03:43 PM
79 vette head's Avatar
79 vette head
St. Jude Donor '10
switch could be grounding out on something in tunnel...could start a fire
Old Sep 9, 2005 | 03:48 PM
72GACRZR's Avatar
72GACRZR
One side only? I would start by looking under the console at how your wires are hooked up. If I remember right, the switches have two hot leads that cause the motor to run up or down leaving and one hot lead in from the power source. You may have caught one under the console cauing a short.
Old Sep 9, 2005 | 04:12 PM
cab's Avatar
cab
it is only the driver side. i like the fire deal surely it wouldnt happen without engaging the switch.
To window troubles
