bare trailing arm weight??
Old Sep 12, 2005 | 05:48 PM
redvetracr's Avatar
redvetracr
Default bare trailing arm weight??
Can someone PLEASE weight a bare trailing arm ?? Inquiring minds (mine) need to know what a bare t-arm actually weights...
...thanks in advance!! ..........redvetracr
Old Sep 12, 2005 | 06:00 PM
tracdogg2's Avatar
tracdogg2
Original arm without bushing = 8.2 lbs.
Mike
Old Sep 12, 2005 | 06:31 PM
Alexarz's Avatar
Alexarz
The aftermarket offset arms seem to be obviously heavier but much stronger than the original trailing arms,
Old Sep 12, 2005 | 11:27 PM
redvetracr's Avatar
redvetracr
THANKS Mike!!
Old Sep 12, 2005 | 11:28 PM
redvetracr's Avatar
redvetracr
and your telling me this...WHY?? I asked a simple question and got a simple answer...case closed!!
...........redvetracr
Old Sep 12, 2005 | 11:46 PM
68/70Vette's Avatar
68/70Vette
The offset trailing arms are much wider where they fit into the frame pocket. This gives less latitude for toe-in and toe-out alighnment. If the frame is not bent, this should not be a problem. And of course, if the offset trailing arms are manufactured with the correct dimensions, alignment should not a problem.
The offset arms also have a different location for the parking brake cable flange. This eliminates the possibility the flange will contact the wheels. The stock parking brake cable, and the repro In-Line tube SS cable will fit the new flange locataion.
The Van Steel (and VHP) offset trailing arms have provisions for anti-sway bars (although the anti-sway bars they sell will not apparently fit the wide tires that the offset trailing arms are designed for!!!). Tom's Differential offset trailing arms do not have provisions for anti-sway bars. Guildstrands offset trailing arms are modified stock trailing arms and will accomodate anti-sway bars. Guildstrand's offset trailing arms are about $1000 and Van Steel and Tom's are about $400 (Prices here are pretty much my best guess, so if you're serious you've got to call or look up the correct price.)
To bare trailing arm weight??
