Part Numbers
Old Sep 16, 2005 | 01:04 PM
Burnt71's Avatar
Burnt71
Default Part Numbers
Any one know if a part stays the same from year to year , do the numbers stay the same in the assembly manuals?
Old Sep 16, 2005 | 01:12 PM
vetsvette2002's Avatar
vetsvette2002
Veteran: Marine Corps
St. Jude Donor '13-'14-'15-'16
Depends on the part, some did, most didn't
Need to know which part you're talking about
Old Sep 16, 2005 | 01:15 PM
big_G's Avatar
big_G
Sometimes part numbers are carried for many years. At the time of production, the part numbers in the AIM are current, but GM is notorious for superceding numbers . Hope this helps.
Old Sep 16, 2005 | 02:18 PM
Burnt71's Avatar
Burnt71
No particular part I'm just trying to figure out what parts are interchanable on different year cars.
Old Sep 16, 2005 | 05:28 PM
standup's Avatar
standup
You can buy a parts interchange manual at your local bookstore or ebay...........
Old Sep 16, 2005 | 05:33 PM
ksbunting's Avatar
ksbunting
There are books available (interchange manuals) that not only tell you whihc parts fit other Corvettes but which other GM vehicles have the same identical part but with maybe a different part number. For instance Pontiac part # xxxx might be the same part as Corvette part # yyyy.
I have seen these books at swap meets and on e-bay from time to time.
Hope that helps,
Kurt
Old Sep 16, 2005 | 05:34 PM
ksbunting's Avatar
ksbunting
There are books available (interchange manuals) that not only tell you which parts fit other Corvettes but which other GM vehicles have the same identical part but with maybe a different part number. For instance Pontiac part # xxxx might be the same part as Corvette part # yyyy.
Hope that helps,
Kurt
Old Sep 16, 2005 | 05:36 PM
ksbunting's Avatar
ksbunting
Standup types faster than I do.
To Part Numbers
