Need paint help...
Here is an overall pic of the right rear fender.
Here is a good pic of those little dots I was talking about.
Most of the fender looked like this, with the cracking paint. Also notice the area on the right where I dug down below the filler. I believe this is the down to the glass.
A shot of the thickness of filler
What are your guys thoughts and advise after seeing these pictures? I am doign the right thing by stripping all this junk, right? Is the car going to need to be gelcoated? Are those areas that are bleeding through going to affect anything, will they come back? I am assuming I should get everything down to the red primer right? Would chemical stripping be a good idea for the fenders? Will it strip the filler off and leave the aftermarket glass alone?
Also, 2 more questions. What is the easiest way of getting undercoating off. And how many quarts of por15 does it usually take to coat a bare frame, when thinned and sprayed through a gun?
I believe you are doing the right thing by removing all the bad paint. Paint, after all is only as good as it's substrate...
I was going to re por it but decided against it last minute and used a black self etching primer
Por 15 (gray primer spot is where it lifted)
Self Etching Primer
( I really should pull that steering box off and clean it
Big G knows a lot about painting and body work (from what I've read on this forum over the past year) so his advise is worth following..
Yes, you should remove the old bondo. That's possibly where some of the bleed thru originated, plus it can be done nicer by you from what you've shown here. It appears the previous work was slap on and puch out work. Your comment about the rough matt up under the fender is a good give away. No true enthusiast would leave it like that. Get up under there, sand it smooth and finish it off properly and closely look at the actual repairs to that section, to prevent problems later down the road once nicely painted. The pattern on the paint seems to indicate a bending of that glass area like a minor inpact to the glass.
I also do not think you need to re gelcoat the car, but you MUST use a good K2 type sealer/primer for the coat between bodywork and paint. You, of course know that, like said above, a paint job is only as nice as the prep work put into it before the spraying, so do it right and do it well now. Good luck. Hope this helps. Glenn
Also, does anyone have a rough estimate of how much por15 I will need to spray the frame? It is bare and sandblasted. Thanks guys!
For the undercoating you can try a pressure washer. It won't take it all off but did a fair job on mine. It at least takes off the easy stuff for you to concentrate on the heavier.
It is messy but it takes a lot of dirt off too.
You can also assume whatever it don't take off is worth leaving on.
If the body work is questionable you could take a shot at it with the pressure washer. It don't have to do a perfect job just reduce what you have to do by other methods.
