Don't even bother with home plating, it's a lot of tedious work, I'd just look around for a company that does electroplating locally, it'll probably be cheaper than buying the set and chemicals
Tedious? maybe.
You could check harbour freights website. I remember something about it but like you can't remember. I don't think its real plating though.
http://www.caswellplating.com/kits/index.html
Has any kit you want and for little things like bolts might be worth it. I have nickel and copper for 4.5 gallons each. The bolts to be nickeled.
Plating yourself has certain advantages. I got into and discovered one more. I can put names or designs on my parts with 2 different plates.
Copper calipers with nickel highlights.
To the tedious. Plating is very simple.
It can be tedious if your buffing parts or copper plating them to fill pits or make them smooth.
Plating is simple but finishing is tedious.
Tedious? maybe.
If you do get into the caswell plating I came up with a cheaper and simpler power supply than a 6 volt battery.
Imagine having a big 10 gallon bucket full of bolts, nuts, washers and what not..then doing all the plating yourself. I just drop my stuff off at the platers, they dump everything in a big drum and hang the larger stuff, comes out perfect every time...for the 100$ or so that it cost me I would certainly not want to do it myself.
I've used the Eastwood system and it works well. However, as mentioned, it is a tedious process and if you are looking at having a bucket of bolts replated it is probably much more economical to have a local plater do it.
