Top-end Engine Build-up questions
1. The intake manifolds are both non-EGR. Do I simply remove those components from my car and everything will be cool? Or will removing these components cause other issues I am not thinking of?
2. How difficult will it be to make the automatic kickdown work with a new carb? Do most carbs have the right interface to work with this?
3. I would guess I will still need to swap out stall converters to something like a 2200-2500. Is this possible without removing the engine?
Shane
