Build Sheet vs Window Sticker
Old Sep 22, 2005 | 08:39 AM
CraigandJanet's Avatar
CraigandJanet
Default Build Sheet vs Window Sticker - Differential
I suppose I could crawl under and count turns, but just for kicks......the original window sticker for my 82 shows a 2.72 rear ratio, but the build sheet shows 2.86. Which should I believe? Just curious..
Old Sep 22, 2005 | 08:51 AM
ruby76's Avatar
ruby76
From: Fairview Heights Illinois, near Saint Louis MO, STL C3 Shark
Good question. I think I'd be more inclined to believe teh build sheet instead of the window sticker. The line workers actually built the car according to the build sheet.
Old Sep 22, 2005 | 09:02 AM
rihwoods's Avatar
rihwoods
Axle ratio 2.87:1 Automatic
Old Sep 22, 2005 | 09:16 AM
CraigandJanet
It's an automatic. I thought 2.87 when I wrote this, but for some reason I remembered it showing 2.86. 2.87 is right, tho. I have a clunking (chunk-chunk-chunk, etc.) (mostly on coast) - noted in an earlier post - that every drivetrain shop (and I) seem to think is the diff., but sounds an awful lot like drive knuckle contact somewhere (all new u-joints and wheel bearings). I picked up a rear half of an 80 frame with a good 3.07, so I have a swap available, but after looking at the clearances at the pinion yoke knuckle on the parts frame, I am going to take a close look at the front diff. mounting bushing in my car. If there is ANY play, I could be having slight contact on the top of the mounting bolt if the batwing pivots only a little. I would LOVE that to be the problem, but probably wishful thinking.
Old Sep 23, 2005 | 06:38 AM
Jim Martley2's Avatar
Jim Martley2
Does your car have the aluminum wheels? I seem to remember reading that you got the 2:72 rear if you had the steel ralley wheels with the 225-70R15 and the 2:87 rear if you had aluminum wheels with the 255-60R15s.
Old Sep 23, 2005 | 11:12 AM
CraigandJanet
Jim, Yes, I have the aluminum wheels with the 60 series tires. I seem to recall seeing that on something once, and checked the original sales brochure which I have and that's what it says, too. By the way, my aluminum wheels got a triple dip of chrome. Lots easier to keep bright. Not correct , but bright.
Old Sep 23, 2005 | 12:25 PM
LemansBlue68's Avatar
LemansBlue68
All '82's are automatics. No manual shifts were sold that year.
Old Sep 23, 2005 | 12:31 PM
Jim Martley2
I am glad you could verify my statment. It's getting tougher to remember some of the more miniscule facts about our cars
I love the look of our wheels with a nice chrome coating BUT I am getting far too CHEAP in my old age to put out the $1,300 requested for them. For now I will just keep on rubbin' on mine with Simichrome Polish!!!!!
Old Sep 25, 2005 | 05:22 PM
CraigandJanet
Naw. Age hasn't anything to do with it. I'm approaching six decades, and I just refuse to grow up. I also refuse to pay that kind of money for shine - luck has it the previous owner didn't mind.
To Build Sheet vs Window Sticker
