C3 Dropped Spindles
Old Sep 22, 2005 | 09:34 AM
rtaylor1234's Avatar
rtaylor1234
Cruising
Default C3 Dropped Spindles
I am in the process of building a replicar on a C3 Vette chassis and need to lower the front end. Does anyone know if there are Dropped Spindles available for the C3? If so, what is the source if known. Thanks,
Ron
Old Sep 22, 2005 | 10:15 AM
72LS1Vette's Avatar
72LS1Vette
One forum member made his own, but in the 4 years I have been on this forum I have never seen reference to commercially available dropped spindles for the C3.
Rick B.
Old Sep 22, 2005 | 11:44 AM
redc3's Avatar
redc3
it is my belief that gm used BB springs in the later c-3's just to get rid of them. my 78 sat up so high in the front i could stick two clinched fists, one on top the other, between my tire and the fender lip. i have seen MANY later c-3's with this same problem. that being said, i have searched every cataloug and company i could get a web address or a phone # for, and have found no drop spindles for a c-3 anywhere. i installed 550 lb. springs which lowered the car 1" to 1 1/2", but still had to cut coils out of those to achieve the ride hieght i wanted
Old Sep 22, 2005 | 03:13 PM
rtaylor1234
Cruising
Default Dropped Spindles
Thanks for the reply. What are the sources for 550# springs? It looks to me like about 1.5" drop should pretty much accomplish what I want.
Thanks,
Ron
Old Sep 22, 2005 | 03:39 PM
groovyjay's Avatar
groovyjay
Thanks,
Ron
You can get them from many different sources, I'd go to Van Steel, since their CS is top notch.
Old Sep 22, 2005 | 03:53 PM
SmokedTires's Avatar
SmokedTires
Cruise-In III Veteran
St. Jude Donor '05
Our very talented Norval made his own, many of the rest of us go with softer front coil springs or even the transverse fiberglass leafspring in the front.
Check out either of these suppliers for more info:
http://www.vansteel.com/
http://www.vbandp.com
BTW, what's the replicar you're building on a C3 chassis? For your info, the chassis is similar from 1963-1978 Corvette.
Old Sep 22, 2005 | 04:22 PM
Twin_Turbo's Avatar
Twin_Turbo
norval made extended spindles, not dropped ones. Now if he had added the extra material to the underside (below the spindle snout) then he'd have dropped & extended spindles
Old Sep 22, 2005 | 06:59 PM
rrent's Avatar
rrent
I thought I read somewhere that the mono-leaf front spring conversions can be lowered. Kinda pricey just to get the front end down, but at least you won't have to be removing cutting replacing removing cutting replacing front coil springs.
Old Sep 23, 2005 | 12:24 AM
rtaylor1234
Cruising
Thanks for the note. I will follow up.
Replicar is '73 Ferrari Daytona Spyder.
R
Old Sep 23, 2005 | 03:16 PM
Yellow73SB's Avatar
Yellow73SB
St. Jude Donor '07
R
corvte into a ferrari! pics please
Old Sep 23, 2005 | 03:21 PM
Twin_Turbo's Avatar
Twin_Turbo
If it tells you anything, the spider used in Miami Vice was a corvette based kitcar too
Old Sep 23, 2005 | 03:45 PM
LIQUIDDRAGON's Avatar
LIQUIDDRAGON
you would be correct. i have the monoleaf spring in the front of my 76 and i can set the ride height and spring stiffness to where i like it. its a very good kit and would recoment it to anyone but if you go all out on the suspension like i did then you can look at spending around 2k on a complete front and rear kit.
Old Sep 23, 2005 | 03:51 PM
Yellow73SB's Avatar
Yellow73SB
St. Jude Donor '07
pics?
Old Sep 23, 2005 | 04:39 PM
Twin_Turbo's Avatar
Twin_Turbo
Crockett's Daytona Spyder was actually a look-alike replica, built using a 1980 Corvette chassis with Ferrari-designed body panels and real Ferrari hardware inside. According to Popular Mechanics, the original replica was "spotted on a lot in Newport Beach by the show's producer."[7] Motor Trend magazine, however, claims the two show cars were bought at an auction. Al Mardikian, an auto importer had the two replicas built by Tom McBurnie, but he found himself in legal trouble and the two cars were confiscated by the Feds.[8] The producers in turn purchased the cars from the government.
Old Sep 23, 2005 | 05:10 PM
Nate '69's Avatar
Nate '69
Interesting. I'd rather have a nice C3.
Old Sep 23, 2005 | 06:11 PM
The Dude's Avatar
The Dude
Ron
This might be a kind of roundabout way to go, but here it is for consideration. Get the Hollander Interchange Manual for '65-'82 'Vettes and check out the suspension components. Some 'Vettes have interchangeable spindles with other Chevys from different years. I looked this up for you:
'65-'67
One-off, no interchange.
'68 Corvette
"Chevy Pass. '67 disc brake; Chevy Pass. '68 disc brake, power."
'69-'82 Corvette
"Chevy Pass. '68 disc brake, manual; Chevy Pass. '69-'70 disc brake."
Contact a vendor who makes dropped spindles for the Chevy that interchanges and see what's available.
It may help to visit a scrap yard and pull a set of spindles from a junked donor car and compare them side-by-side with your 'Vette units just to be absolutely sure.
Don't know whether it's practical, but that's an option for you, anyhow, if you want to do the leg work and research. If you DO find an interchange and convince yourself that it will, in fact, work, my suggestion would be to omit the word "Corvette" when you're talking spindles with vendors. Tell them instead you want them for your '69 Caprice or whatever. Otherwise I'm sure they'll swear up and down they won't fit Corvettes.
Old Sep 24, 2005 | 01:45 PM
rtaylor1234
Cruising
Hey, that is a great suggestion! Thanks for doing the research. I will follow up and see what I can find out there.
Thanks a bunch!
Ron
To C3 Dropped Spindles
Old Sep 24, 2005 | 01:48 PM
rtaylor1234
Cruising
Regarding request for pics -- Don't have any at the moment, but will take some and post shortly. Looks very much like the pics posted by Twin Turbo except in a dark blue with shale interior. Still a work in progress, however - witness the need to solve the front end problem.
Pics to follow.
Ron
Old Sep 24, 2005 | 02:45 PM
The Dude's Avatar
The Dude
Thanks a bunch!
Ron
Let us all know whether it works out. I formulated that idea a couple of years ago but never followed up on it.
Old Sep 24, 2005 | 02:47 PM
Twin_Turbo's Avatar
Twin_Turbo
I'm pretty sure the impala spindles are either exactly the same or very close to ours. I talked to coleman racing a long time ago about the impala spindles and from what I remember there only was a bit of difference in the inner wheel bearing so you could probably have some machined for the proper sizes, there are aftermarket impala spindles available w/ altered snout heights.
