Squeaking Distributor
Old Sep 27, 2005 | 02:31 PM
Apache61's Avatar
Apache61
Default Squeaking Distributor
I just noticed a squeaking noise and it seems to be coming from the distributor. Any thoughts as to what might cause this? Thanks in advance for your help.
Old Sep 27, 2005 | 02:58 PM
big_G's Avatar
big_G
Internal arcing can cause a squeaking sound...I speak from first hand experience! But on the other hand, if it hasn't been lubed in a while, you might tear it down and check her out.
Old Sep 28, 2005 | 08:14 AM
Apache61's Avatar
Apache61
ttt
Old Sep 28, 2005 | 08:23 AM
69ttop502's Avatar
69ttop502
If it is a tach drive dist., it could be the cross gear or the cable itself.
Old Sep 28, 2005 | 08:42 AM
Apache61's Avatar
Apache61
It looks as if there is a speedometer type cable coming out of the base of the distributor. Also, the squeaking noise is in synch with a fluctuating tach gauge at idle. Hopefully it's something simple and I don't have to replace the distributor.
Old Sep 28, 2005 | 12:13 PM
Mike Ward's Avatar
Mike Ward
Depending whether you have a rat or a mouse motor, you might just want to leave him more food.
Old Sep 28, 2005 | 04:24 PM
ruby76's Avatar
ruby76
From: Fairview Heights Illinois, near Saint Louis MO, STL C3 Shark
That's the tach drive. Sounds like you need to lube that cable before it snaps in two.
To Squeaking Distributor
