fuel cutoff valve
Old Sep 29, 2005 | 03:24 PM
Shrike's Avatar
Shrike
Default fuel cutoff valve
I'm thinking about installing a fuel cutoff valve (among other things) as a theft deterrent.
What do some of you use?
Is this a hardware/ auto parts item? or do I need to order something special?
thanks,
Scott
Old Sep 30, 2005 | 04:20 PM
68/70Vette's Avatar
68/70Vette
I'm thinking about buying one also, not as a theft deterent, but to shut off the gas tank when I'm working on a fuel pump or a fuel filter.
I think Earl's sells a shut-off.
Old Sep 30, 2005 | 04:35 PM
Glass Act's Avatar
Glass Act
From: 406ci SB, AFR 180 Heads - 490 HP @5,600 RPM 529 lb-ft @ 4,100 RPM
I'd say any good ball valve would work as long as it's a brass ball and not those with a nylon ball inside.
Old Sep 30, 2005 | 04:44 PM
comp's Avatar
comp
Ok ware to would put if not elec. ???
Old Sep 30, 2005 | 04:45 PM
GTR1999's Avatar
GTR1999
A pro will just flat bed it if they want it.
I think Smith & Wesson in Springfield MA makes some of the best deterrents, I like their hand held .357 mag model. Stops thiefs with a small piece of lead to the head.
Old Sep 30, 2005 | 04:48 PM
ltlevil's Avatar
ltlevil
If you do a search there have been several discussions about theft deterrents. One of these had someone detail how they installed there isolation valve near the tank. Usually for something like this I would look for a marine application they are generally good quality products and are made to stand up to the elements.
Old Sep 30, 2005 | 05:01 PM
comp's Avatar
comp
use the car as bait what about a "car trained" dog that is mean as Heck
Old Sep 30, 2005 | 05:28 PM
ltlevil's Avatar
ltlevil
It works but against the law-something about hunting over a baited field or something.
To fuel cutoff valve
