Headlamp Protection Shields
Old Sep 30, 2005 | 04:34 PM
standup's Avatar
standup
Default Headlamp Protection Shields
How many of you have these on your Vette ???????
Was this a factory item or aftermarket ??????
I'm thinking of removing mine to show off my new grills a bit more.....just curious if those who don't have them have noticed any damage to the bezels or headlamps.......
Old Sep 30, 2005 | 04:57 PM
Gordonm's Avatar
Gordonm
They are on mine. These were factory to protect the headlights while in the down position. I don't like it without them. Looks funny to be able to see the headlights while down.
How is it going to show off your new grills more when they are behind the grill?
Old Sep 30, 2005 | 04:59 PM
gq82's Avatar
gq82
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
These are factory items and in my opinion I'd rather not see the headlights through the grill.
Edit; Gordonm, you said it better than I did.
Old Sep 30, 2005 | 05:31 PM
standup's Avatar
standup
I thought it might create a backlit situation, maybe some reflection off the white bezels and the headlamps....dunno, guess I'll have to try it.....
Thanks for your comments........
Old Sep 30, 2005 | 06:39 PM
Z-man's Avatar
Z-man
I've still got them on mine. They are full of scratches from where rocks have hit them instead of busting the lights. Also, I don't like seeing the headlights when they are down - they are supposed to disappear!
Old Sep 30, 2005 | 07:36 PM
cosmicvette's Avatar
cosmicvette
I don't have them on mine....but want them! Id also prefer not to see the headlights behind the grille. Will definitly be buying a set sometime.
Old Sep 30, 2005 | 07:56 PM
rihwoods's Avatar
rihwoods
Here are mine...gone...did it for increased airflow to radiator along with no front plate...Duntov would have grinned at this,as he did not like the flip lights anyway for same reason...AIRFLOW to BB's...
Headlights are more exposed when up....
Old Sep 30, 2005 | 08:19 PM
601P's Avatar
601P
I have mine.....
Old Sep 30, 2005 | 08:28 PM
sb69coupe's Avatar
sb69coupe
Um, the C3 draws the air from under the front valance. not through the grills. The headlamp shields are no larger than the front cross section of the lights and bezel itself, so I fail to see how removing them could increase your cooling margin.
Did you actually measure an operating temperature reduction when you removed the shields?
Old Sep 30, 2005 | 08:49 PM
StickShiftCorvette's Avatar
StickShiftCorvette
I still have mine.
My car is a '69 built on the first day of production (SN - 00035) and it has much smaller shields than a friend's mid year production '69. I'd assume '68s have the smaller ones found on my car.
Old Sep 30, 2005 | 09:30 PM
rihwoods's Avatar
rihwoods
Certainly...gained 72 sq in just for the front plate,and another 10 sq in from both the headlights....so 82 sq in more area for air to flow with a gain of 5-6 F reduction...means more at speed than city,but every little bit helps...
Rich
To Headlamp Protection Shields
