Racing Helmets
Any suggestions?
I don't know if he was joking around with me or not ???
UH-OH. Looks like I will have to make new decals for my current helmet...
I highly recommend going somewhere you can try several types and brands on. Like shoes there a some that will just fit better.
-Chris
I think mine is something like this:
Check with your sanctioning organization to see what they will allow. Some autocrosses will allow DOT helmets (motorcycle) but check first. Some events will even hae loaner helmets and there are even entrants that will bring extra helmets.
I got my Bell Mag-4 helmet from Helmet City. They have good prices and a wide selection. But be careful in determining the size you need. I had found out that (for example) Bell and Simpson helmets are not sized the same way. They have different methods of determining the size you wear.
I would find a large bike shop and try on some different helmets. Most big bike shops will have Bell, Simpson, and Biffe helmets for bikes but the sizing will be the same within the brands. Try one that fits and use that size to order.
I would definitely go with a "SA" rated helmet. It's sole use is for motorsports and not bikes. "M" rated helmets are for bikes but not motorsports. The SA-rated helmets feature Nomex lining and will handle multiple impacts. Choosing between open-face and full-face is your choice but ask if the sanctioning organization requires a specific style.
I went with open face as I wear glasses and I can put the helmet on without removing my glasses. There are full-face models for glasses wearers but I found that you have to remove your glasses to put them on.
A long time ago here, I read a thread about buying helmets. One of the points I remembered was regarding just how good or expensive a helmet do you want or need. Somebody replied that "if you have a $10 head, buy a $10 helmet". Thought that was pretty sage advice....
I figure the helmet don't stop at protecting your life but reducing hospital stay and reconstructive surgery.
I do have to take off put on glasses but this helmet also has whats called a helmet restaint (mostly for boats) and is a pain by itself so the glasses thing is minimal. If glasses is the only concern don't restict a choice based on that. Once they're on they're on.
BTW once a helmet is "used" it is no good anymore. The foam inside the helmet has more to do than the shell for protecting your brain, it crushes and can't do that a second time.
