[NoVA] Steeroids Install on Sat Oct 8th
Old Oct 3, 2005 | 08:34 AM
ShaneLU97's Avatar
ShaneLU97
Default [NoVA] Steeroids Install on Sat Oct 8th
I am planning on installing my steeroids kit into my 73 this Saturday if anyone is interested in seeing / helping. Never done any steering work before but my guess it is a cross between brakes (hydraulics) and suspension (lots a linkages, joints, etc) work.
If interested, shoot me a PM or e-mail.
Shane
Old Oct 3, 2005 | 09:10 AM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
have you ordered the new bearing for the lower steering column?
starting at post number 3
http://forums.corvetteforum.com/showthread.php?t=960162
the rest of the steeroids install starts at Post 10
Old Oct 3, 2005 | 10:58 AM
ShaneLU97's Avatar
ShaneLU97
Yup. Got it from Ecklers when I ordered my steeroids kit.
Shane
Old Oct 3, 2005 | 11:51 AM
bobs77vet's Avatar
bobs77vet
Shane
i forgot to mention to start soaking that now with a loosening solvent and the rag joint bolts also. sounds like you are good to go!!!!!! lets see pics as you do it, you will like really it, i'm a big fan!
Old Oct 3, 2005 | 12:11 PM
ShaneLU97's Avatar
ShaneLU97
Good idea.
I am actually taking the rest of today and all day tomorrow off to finish re-doing the seat covers and put in new carpet. I will start that while I am out there.
Shane
Old Oct 3, 2005 | 01:40 PM
ThereIsNoSpoon's Avatar
ThereIsNoSpoon
I still plan to help out on Sat, I'm actually in the middle of installing mine as well.
Is that necessary for installing the steeroids, this is the first I have heard of it.
Old Oct 3, 2005 | 02:03 PM
Fevre's Avatar
Fevre
Not necessary but chances are you car needs it, not very expensive and takes slop out of the system if the bearing is worn. Not sure if it will work but try grabbing the lower shaft just above the rag joint and move it back and forth (or up and down) to see of there is any play at the end of the lower steering colum.
Old Oct 3, 2005 | 02:25 PM
bobs77vet's Avatar
bobs77vet
I
you don't want any additional slop in the steering column since the steeroids is so good. You only want your intended movements to make it to the rack and pinion unit.
Old Oct 3, 2005 | 02:50 PM
ThereIsNoSpoon
Originally Posted by Fevre
Not necessary but chances are you car needs it, not very expensive and takes slop out of the system if the bearing is worn. Not sure if it will work but try crabbing the lower shaft just above the rag joint and move it back and forth (or up and down) to see of there is any play at the end of the lower steering colum.
Thanks for the info guys, I guess I'll jump on the bandwagon.
Old Oct 3, 2005 | 07:46 PM
ShaneLU97's Avatar
ShaneLU97
Did you put your car on jackstands and remove the wheels for installation or did you drive the car up on ramps and install around everything.
Shane
Old Oct 3, 2005 | 08:25 PM
bobs77vet's Avatar
bobs77vet
mine was on jack stands and the engine was removed
Old Oct 3, 2005 | 09:36 PM
ThereIsNoSpoon
Shane
I drove it up on my ramp structure (12" for the front and rear). I then removed the middle section of my ramp structure and jacked the car up another couple inches to get the front wheels off the ramp structure. Next, I put jackstands under the frame so that the front wheels would be able to be turned freely. I have managed to finally get everything out of the car without removing my headers (looking back on it, it may have been quicker to just remove the headers). In order to do this I had to remove the pitman arm from the steering box so that the steering box could be lifted out of the car. I have not had time to install the steeroids yet, but I hope to be done by the end of Friday so that when I help you I will have a better idea what to do. Also, I have a pitman arm puller and pickle forks if you want me to bring them.
Old Oct 3, 2005 | 10:00 PM
fcoppola's Avatar
fcoppola
you are going to love it!!!
If I can install steeroids .. ANYONE can!!!
You wont have a problem!! I drove mine today for the first time since installing it and WHAT A DIFFERENCE!!!
I can't say enough about it!
Its off to the alignment shop on saturday!!
Dont forget to align it when you're done!
Old Oct 3, 2005 | 10:03 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
I just drove my car up on the ramps and left it setting on the ramps and worked that way. My reasoning was to help maintain some kind of alignment. After I was done with the install, I wound up using the string to get it close to aligned so I could take it to the alignment shop.
Old Oct 3, 2005 | 11:09 PM
stinky's Avatar
stinky
Hey, Eddie, I want it back Was wondering how your install went.
To [NoVA] Steeroids Install on Sat Oct 8th
