does anyone know....
Old Oct 6, 2005 | 10:10 AM
samson80's Avatar
samson80
Default does anyone know....
I was wondering at what speed do you get the best mpg, I have searched for charts but couldn't find any. I have heard it is about 55-65mph??
Old Oct 6, 2005 | 10:14 AM
ismithlj's Avatar
ismithlj
It depends on your gearing. It is more of a matter of at what RPM in your top gear do you get the best mielage. I may be wrong but I believe it is the RPM at which your engine pulls the most vacuum because old style fuel mileage gauges were just vacuum gauges.
Old Oct 6, 2005 | 10:18 AM
samson80's Avatar
samson80
Is there any general speed, or is 55-65mph even close??
rihwoods's Avatar
rihwoods
I find it at 60-65 with my 78 L-82 4 speed 3.70:1 gears...max 16 mpg....
..don't have a clue on the 69....
turtlevette's Avatar
turtlevette
St. Jude Donor '03,'11
many years ago i had one of those computers in my car that monitored real time fuel consumption and speed yada yada yada.
i got the best instantenous MPG at around 40 mph. Somewhere in the 20s if i remember right.
All these dudes getting mid 20's MPG in their C3 must have been taught to drive by their grandmothers.
Old Oct 6, 2005 | 10:20 AM
samson80's Avatar
samson80
What were you driving?? I drive a 80 corvette, right now I don't know the specifics on it.
Old Oct 6, 2005 | 12:43 PM
stingr69's Avatar
stingr69
I think you should theoreticaly get the best mileage when you have the highest brake specific fuel consumption. That would have the highest thermal efficiency.
Highest Vacuum probably optimizes highest volumetric efficency (a component of overall thermal efficency) and that is a good thing but probably not the exact point of maximum fuel efficency but I am just shooting from the hip here.
Obviously this optimal speed will vary depending on cam timing, gearing, wind resistance, etc. Every car is different especialy if it is modified from stock. Is that a screwy statement or what?
-Mark.
Old Oct 6, 2005 | 12:47 PM
nhlgopens's Avatar
nhlgopens
If I'm driving my Vette - I could care less about mpg. It sucks gas at about 12 mpg average. I can tell you that the harder you stand on it - the worse your mileage will be...
Old Oct 6, 2005 | 12:52 PM
samson80's Avatar
samson80
Thanks for the help I guess that it is diffrent in every car, I will just have to do a few experiments myself!
Old Oct 6, 2005 | 02:33 PM
Aflac's Avatar
Aflac
Cruise-In 5, 6 & 10 Veteran
St. Jude Donor '09
i get 10-12 mpg....i do have a tired transmission however...
Old Oct 6, 2005 | 02:55 PM
G dad's Avatar
G dad
From: THE OLDER I GET THE BETTER I WAS! NORTHERN ONTARIO
I get about 16 or 17 Hwy. 55 to 65 mph. 79 L48 auto 3.73
Old Oct 6, 2005 | 10:53 PM
StickShiftCorvette's Avatar
StickShiftCorvette
While I've never driven slow enough to find out, generally, you need to be in high gear at the lowest road speed that the engine runs smoothly. Mileage is related to engine efficiency and wind resistance, and unless you have a radical cam, low revs (minimum internal friction) and low speed (minimum external load) will give the best mileage.
Sticks do better since they waste no energy pumping oil, have NO gear losses (on 4 speeds w/1:1 top gears), and have no slipping torque converters or disengaged, but still dragging (wet internal) clutches or brakes.
OD autos make up for some auto losses by running the engine slower, but the engine still needs the same power to keep the car moving as a direct drive auto at any given speed.
Old Oct 6, 2005 | 11:24 PM
ETM's Avatar
ETM
If your really concerned about fuel mileage consider adding an overdrive tranny.My car runs about 70MPH on the freeway at about 1800 RPM.The 700R4 also has a beter more aggressive 1st gear than the TH350.
Old Oct 7, 2005 | 08:04 AM
mooneyd's Avatar
mooneyd
Zero
Sorry, coun't resist
Old Oct 7, 2005 | 12:36 PM
71redskin's Avatar
71redskin
i'm no expert but i always thought a car ran its most efficiently at halfway the redline on the tach...so if your redline was 6k...3k would get you the best mileage...just my .02
Old Oct 7, 2005 | 12:43 PM
Entropy's Avatar
Entropy
St. Jude Donor '08-'09
I'm going to have to disagree with this. My C5 friends get their best mileage with their 6 speed when its close to 2000 rpm (over 30 miles to the gallon). I think stickshiftcorvette has it right. Minimize load on the engine to allow it to be efficient.
trw
To does anyone know....
