Home Painters step in side please...
1 gallon primer-surfacer + required reducers and activators
1 to 1-1/2 gallons base-coat + required reducers and activators.
1 to 1-1/2 gallons clear-coat + requierd reducers and activators.
G/L
Mark G
Second paint is cheaper generally cheaper in larger quanities. Three it really sucks when you have to run out for more paint. And if its a custom mixed color there is always the chance that the don't mix the second batch exactly the same. Finally, catalized paint stores well in sealled containers. If you ever need to do some touch up you already have paint you know that matchs.If you have not priceed good paint may give you sticker shock. Go with a good base coat clear coat system. I like personnally like ppg. Don't skimp on the polyurithane one step systems. They never look as good in the long run. Just my two cents.
The money pit has:
-Two coats of primer/surfacer (approximately 3 quarts);
-One coat of epoxy primer on top of the surfacer (approximately 1 quart);
-One coat of sealer(approx. 1 quart);
-Two coats of base (approx. 2 quarts);
-Two coats of clear (approx. 2 quarts);
My car came out great, but again, I can't stress the prep enough. I thought I was through with the bodywork, and the paint was applied. I looked under the front where the nose wraps to the fender, and noticed some real "@#$ty" body work on my part. It is not real noticeable, but I know it is there. Also, be prepared to do a lot of color(water) sanding and buffing. It is almost impossible to get these old cars completly clean, and some trash is going to wind up in the paint, just cut and buff. Although, from your pics, it looks as though you are doing a frame off, and will probably not have as many problems. This may sound odd, but wash the under side of your hood, before you paint. Ask me how I know why to do this now
1 gal DP40LF
2 gal K36 (only because my body was bead blasted and I had to lay down 6 coats to get it filled!)
1 gal DBC color
1 gal Concept 2021 clear
and of course the associated reducers and catalysts. Of the color and clear I used less than a 1/2 gal to do the body and I expect much less than that for the remaining parts. This is a complete spray as well, door jams, hinge area, the whole 9 yards.
I know they all say the colors cover....they don't! so better safe than sorry.
Also if you seal the car, you may see imperfections prior to applying the base color and they can be corrected at that time.
Some air flow as in an open window at one end and the garage door cracked open at the other? Or the same with a box fan in the window facing out? Or?
