Help with wheel studs !!!!
Old Oct 11, 2005 | 11:22 PM
Palengke's Avatar
Palengke
Default Help with wheel studs !!!!
Hello everyone,
Yesterday, I was doing 75 MPH on the frreway on my '74 coupe when my steering wheel shook and loud metallic slap in the front. I pulled over thinking I had a tire blowout, but my tires were all good. I continued driving for a few hundred feet with the metallic slap and I decided to pull over and had the toy flat-bedded back home. I soon found out that I lost 4 of 5 wheel studs on my front left wheel. I actually broke two studs off. One stud kept the wheel on and prevented what could have been a serious accident.
My question is should I replace the entire hub or should I just change the studs. Are the studs even available in the aftermarket? Where do I get them? Please advise. I need to get this baby back on the road.
Old Oct 12, 2005 | 08:32 AM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
you were lucky
These wheel studs are available, the cheapest at AutoZone (quality ??) ARP has the good stuff :
http://www.arp-bolts.com/
Old Oct 12, 2005 | 10:39 AM
427V8's Avatar
427V8
C6 the C5 of tomorrow
Move on up to 1/2" studs if you can drill the hub larger.
Otherwise ARP 7/16's are good
Old Oct 12, 2005 | 11:04 AM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
1/2" studs have a .580" knurl - that's some major drilling
I bought M12 studs with a .480" (12.2mm) knurl, I drilled 15/32" (11.9mm) with a handheld drill the hole turned out to be 12mm so the threaded part fit through the hole and the knurl had to be pressed in - perfect fit
Old Oct 12, 2005 | 12:46 PM
GTR1999's Avatar
GTR1999
NAPA stock them and the fronts are not bad to do. If ARP makes them then that some added insurance. The new lug nuts I bought from the parts stores are a problem too, The threads roll the first time you remove them. I have to replace them every 4th - 5th time off. One rolled and locked the nut on and the impact gun sheared the stud off. It's a rear stud too,much more of a hassle to change with the backing plate on.
Gary
To Help with wheel studs !!!!
