Strokervette Project Progress w/pics
knotted wire brush - has threaded center. (same section @ Home Depot).
They last 10 times longer and remove stuff "wicked" fast.
Just don't get it near your clothes and wear eye protection - for sure.
Check out the pics at the bottom of this post:
http://forums.corvetteforum.com/show...um_id=3&arch=1
Also, I have to say be careful how much of the front support
structure you remove. The frame extension holds up the radiator
support, which holds up the inner fenders. This combo holds
much of the front body weight. Relying on less may result
in unwanted stress cracks - particularly in the front corners
where the bumper bar ties into the fender reinforcements.
Good luck ... looks like you are moving right along.
But first things first, I have to get the rear susp parts and that will take a little time as I just ducked out a load on the rear to get it rebuilt so next is new offset trailing arms. Mine aren't too bad but that is a lot of work to clean and rebuild them my self. I would feel better about it if they were new and ready to bolt on. New calipers are in the works too.
I will try to take some more pics soon.
Well I got some new parts, crossmember bushings, composite spring, shock mounts, shocks, gas tank gasket and overflow tub, trailing arm shim kit, and lowering bolts. I just have to wait to get my crossmember reinforcment discs then I can start to re-assemble everything. But I did get to put the bushings in though and they actually went in 100 times easier than they were to get out. I also got to wire down the rest of the frame under the car and put a layer of paint on it so it won't rust for now. Check out the pics.................
Here is a before shot of the rear bumper still on the car.
And this is what how it will be for when I get the new fiberglass bumper cover. (Without bumper installed) All of the lights are going to be replaced with the "bubble style" lights and the cover is going to be an "80 style". With fiberglass I can mount the lights directly to the cover and don't need the original brackets.
More pics to come soon!!!
