Turn signal probs
Old Oct 12, 2005 | 10:21 PM
mlub's Avatar
mlub
Default Turn signal probs
My blinkers started to only work if I turned my steering wheel a little one way or the other and they would blink slower than usual... and now they're not workin at all...not even the interior lighted arrows blink. Any ideas?
Old Oct 13, 2005 | 07:18 AM
G dad's Avatar
G dad
From: THE OLDER I GET THE BETTER I WAS! NORTHERN ONTARIO
Sounds like it could be the the directional switch...but you might want to check the flash unit....as well as all the lamps to make sure no bulbs are burned. Fuse? it may have snaaappeeddd because of a short. good luck.
Old Oct 13, 2005 | 08:28 AM
Vette Gator's Avatar
Vette Gator
I wonder about the wires that run down the column. Space is pretty tight and it's not impossible to get intermittent shorts that might cause these problems. The new switch will come with new wires attached so it will cure this problem.
To Turn signal probs
