Fuel Pump Part# Needed
Old Oct 13, 2005 | 10:27 AM
sarchevyman's Avatar
sarchevyman
Default Fuel Pump Part# Needed
I have a 68 vette 327 350hp, trying to find a pump for it that has a return line. All part stores around here have a pump listed but none have the return line that I need. Thanks for any help here, Steve
Old Oct 13, 2005 | 11:07 AM
Fevre's Avatar
Fevre
Think you can use any year with the return, got one for my 73 at the local parts store. You might have a problem finding one for a 68 since they had so many 1 year only parts, try having them look for a diff year.
One thing might want to do when you get one is to somehow filter the fuel coming out initially, I just happen to have one of those dangerous glass filters (have it removed now) between the pump and carb which caught some rubber debris, prolly from the internal seals in the pump.
Old Oct 13, 2005 | 11:17 AM
sarchevyman
I just figured it out, I ordered a set of fuel lines and the correct filter. The system is vented through a fuel return off the filter, its a three line setup. Heck its only money!!! Thanks
Old Oct 13, 2005 | 12:07 PM
PRNDL's Avatar
PRNDL
GF432 fuel filter is the original part that has the fuel return line outlet.
To Fuel Pump Part# Needed
