'76...early or late?
Old Oct 16, 2005 | 01:17 AM
seventysixvette's Avatar
seventysixvette
Default '76...early or late?
Howdy folks. Ok, I've researched to no avail. I now know what a 'birdcage' is. I know why my '76 doesn't have the vents on the deck. I even know how to tell hand laminated 'glass from SMC, and why it matters. BUT, I can't find a way to tell an early '76 from a late '76. There are a few parts I need to start looking for where this matters. Is there an easy, sure-fire way to tell? Serial number, or special trim, seat style, anything?!? I'd sure appreicate any hints or suggestions.
Thanks! John
Old Oct 16, 2005 | 10:36 AM
Kilroy1024's Avatar
Kilroy1024
I've got a 76. Don't know what the difference between early and late is.
But I'll be watching this thread to find out.
Don't know if this helps:
Serial Numbers: 1Z37L6S400001 through 1Z37L6S446558
http://www.idavette.net/facts/76.htm
Old Oct 17, 2005 | 09:39 AM
jimvette999's Avatar
jimvette999
I know there is a difference between the upper radiator hoses on early and late 76's
you could go to the parts house, ask for a hose for early and late 76 and compare it to the hose shape yours has
I believe late refers to a production date from July on but I'm not sure.
I know this helps very little but it's all I know
Old Oct 17, 2005 | 01:20 PM
JustinGJ's Avatar
JustinGJ
Also different rear badges, either 6" or the larger 8" ones used through '82 I believe. I thought I heard once that there is a difference between the early and late rad shrouds, and I wonder if the overhead dome light wasn't added sometime during the year, not sure on that one though.
Old Oct 17, 2005 | 03:54 PM
seventysixvette
The rear end isn't stock, my dome light says it's an early, my plastic fan shroud says late. I'm corn-fused. My radiator support bracket is rusting out, and was one of the reasons I started looking into this. I haven't found a clear picture of the two different radiator brackets to compare, and in all honesty, the way some of this poor baby has been cobbled together, I don't know if I'll EVER know just how it rolled out of the factory.
On a different note, sorry, I don't know how I ended up with two threads on this issue. I went in to edit the original, and ended up with two completely different posts of the same thing.
Don't know what I did, sorry......John
Old Oct 17, 2005 | 04:28 PM
ruby76's Avatar
ruby76
From: Fairview Heights Illinois, near Saint Louis MO, STL C3 Shark
Post a pic of your radiator/shroud brackets. late 76 had the shroud bracket incorporated with teh radiator support bracket. early 76 had separate brackets closer to the center to support the shroud - or at least that's what I've been told.
Old Oct 18, 2005 | 01:40 AM
Kilroy1024's Avatar
Kilroy1024
Doesn't that help?
Last 5 digits are the sequential production number.
If its 40,000+, your probably late.
Less than 10000, your probably early.
Old Oct 18, 2005 | 08:47 AM
ruby76's Avatar
ruby76
Doesn't that help?
That helps, but lets say your vin was 25,000.........
not me, mine is late, high 40,000 for my vin.
Old Oct 18, 2005 | 11:56 AM
seventysixvette
Thanks for all your posts. My #s are 413,299 or 13,299. I guess I have a late-early, or a very early-late (heh, heh) I'm findin' more late/early mix in other areas. It looks like former owners stuck on what they could find, or the production line simply used what parts was in the feeder bins before starting on the newer 'late year items'. Thanks again. John
Old Oct 18, 2005 | 02:46 PM
vetteboy1976kr's Avatar
vetteboy1976kr
There are a couple of ways to check to see if you have an early or late '76. Although, since the following changes were RMC's (rolling model changes), you could have a combo of them.
1. Radiator support: the early has two supports on the botton that the radiator rests on. The late has one long one about 4" wide that supports the radiator. The early is the same as 73-75, and the late is the same as 77-82.
2. Rear emblem: The early emblem is 6.25" long and the late is 8.25" long.
3. Rear bumper: the early bumper cover has the indentation for the smaller emblem, the late does not.
4. AC compressor: the early has the longer A6 compressor (about 14" long) and the late has the shorter radial compressor
My VIN is 35817 and most people would consider it a late car. It does have a late radiator support, and the brackets for the longer compressor (compressor was long gone), BUT it has the early rear bumper cover and emblem. I guess mine is more of a bastard child than I thought!
EITHER WAY POST SOME PICS OF YOURS!
Old Oct 18, 2005 | 03:32 PM
wcsinx's Avatar
wcsinx
There is no definitive VIN that says early < > late.
Old Oct 18, 2005 | 10:44 PM
glen242's Avatar
glen242
I have a mix of early and late stuff on mine. 29750. Depends upon the specific part.
Old Oct 19, 2005 | 12:36 PM
markdtn's Avatar
markdtn
All these things are good indicators. I did not realize that some were built that mismatched the a/c compressor and the core support. Interesting that some are out there.
Old Oct 19, 2005 | 11:43 PM
seventysixvette
Hmmm, everything on mine points to early with one odd-ball. I have: the early interior light, the early long A.C. compressor, the two seperate supports under my radiator. Some one must have modified my upper radiator mount, 'cause I have a plastic/fiberglass fan shroud. Whoever done the dirty deed must have been real good, because it looks straight stock. Not cobbled or shade tree engineered at all. Live and learn. You all have given some real pearls of information in this thread.
>>EITHER WAY POST SOME PICS OF YOURS!<<
Lordy! It looks like a real mess right now! Interior tore completely out, 1/2 of the body sanded and all of it de-chromed and de-emblemed. Both of my headlight assemblys are out and on the work bench for rebuilding and touching up this winter. I've got the front bumper and spoiler bolted on for final fitting and tweaking (both are bone white with shots of red and grey primer in odd places and look really out of place).
NO, WAIT! It's that time of year for horrible things to scare you right out of your skin. Maybe I SHOULD post a pic....(low, evil laugh...) John and his Frankenvette
Old Oct 20, 2005 | 12:35 AM
JustinGJ's Avatar
JustinGJ
So does that mean you don't have the overhead light, just the rear compartment one?
Old Oct 20, 2005 | 11:35 AM
seventysixvette
Exactly. Mine has three lights. Left floor (under the dash), right floor. and on the rear wall behind the seats.... John
Old Oct 20, 2005 | 01:22 PM
ruby76's Avatar
ruby76
same with my LATE LATE 76 - born on date 7/6/76
To '76...early or late?
Old Oct 20, 2005 | 02:43 PM
seventysixvette
Hmmm...proves not to make snap assumptions, and there seems to be no difinative answers on a whole vette, just individual componets..
John.....live and learn
Old Oct 20, 2005 | 03:19 PM
Swiftie 76's Avatar
Swiftie 76
My 76 has the same three lights and it was born Nov 75.
Old Oct 20, 2005 | 04:08 PM
ruby76's Avatar
ruby76
Was there an option for interior lights?
