Which torque wrench? Beam or "Click" style
Old Oct 16, 2005 | 09:44 AM
surfshark's Avatar
surfshark
Default Which torque wrench? Beam or "Click" style
I'm not sure if this should be in General, so I apologize in advance...
Which style torque wrench do you prefer or deem more reliable? The Beam or "Click" style? Upon seeing mine (click 1/2"), a local engine builder and racer told me he doesn't trust them, mainly due to losing their calibration. I know you're supposed to set them back to zero after use, to avoid this though.
Also, for engine buiilding purposes do you use 3/8 or 1/2'' drive wrenches? Thanks for any input!
Old Oct 16, 2005 | 10:07 AM
GDaina's Avatar
GDaina
Click type...I have three....Proto that I've had since the late 60's and still accurate, Craftsman that is a piece of junk...at times won't click when the proper torque is reached, and a $12.50 Harbor Freight clicker, that is as accurate as my Proto. Have the H.F. for 1.5 years and still clickin'.
Get the 1/2"
Old Oct 16, 2005 | 10:08 AM
BBShark's Avatar
BBShark
St. Jude Donor '05-'07
I think beam wrenches are hard to use on high torque fasteners like head bolts. You have to be able to see the pointer and that puts you in a poor position to get much leverage. I use my beam wrench to check the calibration of my click wrench.
Old Oct 16, 2005 | 10:09 AM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Personally I prefer the clicker type. You can send the things off and have them checked once a year to ensure they are still in calibration. Having said that, you will not use the torque wrench nearly as often as your mechanic should. I have both, 3/8 and 1/2 drive torque wrenches also. Both of them came from Sears and I have had them for around 8 years and both of them have problems that Sears will not warranty. Buy from someone else besides Sears. Lowes or Home Depot actually sells one that is made in USA but I cannot remember which store it is offhand.
Whew!!
Old Oct 16, 2005 | 10:12 AM
David Ey's Avatar
David Ey
Well, the click type are good enough for precision aircraft work. I think they are plenty accerate.
It is more convenient to use both sizes for me.
norvalwilhelm's Avatar
norvalwilhelm
I have both and only use the clicker.
Old Oct 16, 2005 | 10:16 AM
carbster09's Avatar
carbster09
Default Clicker!
I only use the click type. I have craftsman and another american brand .. ATI, maybe. I think I purchased them from Eastwood and I prefer them to Craftsman.
I have a selection of sizes that I use; of course. However a set of those $ "Sidewinder" ratchets is VERY handy. Sometimes its hard to beat 1/4" for tight spots....
carbster
Old Oct 16, 2005 | 10:19 AM
1979toy's Avatar
1979toy
Most of the name brand manufacturers guarntee their click torque wrenches to be +-4 percent while the beam style from the same manufacturer will be guarnteed to be within +-2 percent.
A bit of dirt or rust on the inner beam of the click type wrench can cause a variation in the reading that you will never notice.
All of that said the click type wrench is much easier for most of us to use. For most work it is only important to have all of the hardware torqued to the same amount and the exact amount is not as important. This is not the case in building engines or rear ends so you will find people involved in those chores either using beam type wrenches or they have a torque wrench checking tool on site for their click type wrenches.
Old Oct 16, 2005 | 10:21 AM
Aflac's Avatar
Aflac
Cruise-In 5, 6 & 10 Veteran
St. Jude Donor '09
at work (air force--work on stealth bomber) we use click type only. we have them calibrated at certian intervals. we have some set rules that we observe to keep them in calibration:
1. if it is cased and dropped, it can be used until calibration time if it has been dropped from a distance of less than 3 feet
2. if it has been dropped while uncased, the max distance it can be dropped before calibration is required is 6 inches.
3. do not use a torque wrench in it's lower 20% of it's calibrated range. Ex: if you have a 30-150 inlb wrench, dont use it for anything below 54 inlbs. go for a smaller torque wrench.
4. prior to use, break the torque wrench thru with it on it's lowest calibrated setting. This ensures that the star wheel inside it is lubricated properly. Proper lubrication= accurate torque.
being a quality assurance inspector, i have to be aware of all the little nuances and rules...
Old Oct 16, 2005 | 11:12 AM
Nvts's Avatar
Nvts
How does one check if your wrench is still accerate?
Old Oct 16, 2005 | 11:21 AM
Aflac's Avatar
Aflac
St. Jude Donor '09
i know if you have a snap on, they actually have an address that you can ship the wrench to for calibration.. i dont know about anyone else....
Old Oct 16, 2005 | 11:44 AM
Twin_Turbo's Avatar
Twin_Turbo
I like the torqometer type wrenches, got em in all sizes and flavors
Old Oct 16, 2005 | 12:31 PM
stingr69's Avatar
stingr69
I have a Craftsman clicker and I have had similar problems with it not clicking when it is supposed to. I would not advise anyone to purchase one of those.
The beam type are better for some uses such as recording break away torque when dissasembling a fastener. This is not possible when using a clicker type wrench. The next one I buy will probably be a beam type but I will keep my eye open for a good deal on a better quality clicker type too.
You can never have too many tools
-Mark.
Old Oct 16, 2005 | 01:53 PM
SHAKERATTLEROLL's Avatar
SHAKERATTLEROLL
I also prefer CLICKER ones. I must be lucky since I have had my Craftsman for over 15 years and has worked great. Now I do keep it in its box and keep it oiled to keep away rust though.
Old Oct 16, 2005 | 02:39 PM
LiveandLetDrive's Avatar
LiveandLetDrive
I worked with professional mechanics last year and on everything from our race cars to 6-digit price sports cars we used clicker type. One of the Testarossas had single-lug wheels and came with its own torque wrench. About 3 feet long and went up to something like 400 or 600ftlbs! There were also torque-o-meters for sensitive things like engine builds.
Old Oct 16, 2005 | 02:42 PM
Lionsden's Avatar
Lionsden
I use to check and calibrate torque wrenches. Day in day out the bending beam torque wrenches by far hold their calibration better than the click type. A bending beam Craftsman as far as accuracy out performs the Snapon and Proto click type. If your not willing to have a click type wrench regularly check go with the bending beam.
Old Oct 16, 2005 | 03:05 PM
lowbuck72's Avatar
lowbuck72
I use clicker type torque wrenches at home and we use 3 in the shop at work, with one backup. I run a Costco Tire shop. I have a torque analyzer and test each wrench for accuracy once a month, I even send our analyzer in to be calibrated once a year. If you asked real nice, you might get me to check your wrench on our analyzer.
To Which torque wrench? Beam or "Click" style
Old Oct 16, 2005 | 06:23 PM
Techno's Avatar
Techno
Usually torquing something like heads or intake means going through a bunch of bolts maybe 3 times. Looking at the beam kind is a pain. Getting a click is go to the next one.
At work on the very specific torquing needs they don't torque but apply direct stretch readings. So many degrees of turn by the pitch of the fastener results in the wanted bolt stretch. The ultimate in accuracy since it isn't affected by oil or no oil....Imagine doing that 3 times!!!
Old Oct 16, 2005 | 06:39 PM
79ls1's Avatar
79ls1
Default A German method called "Goodentight"
I have calibrated fingers and therefore don't need a torque wrench.
Sorry
I've always used the clicker type and have it calibrated annually.
Old Oct 16, 2005 | 07:09 PM
surfshark's Avatar
surfshark
Thanks for the advice. Your input is always very helpful!
