Horsepower???
Old Oct 17, 2005 | 01:49 PM
markbett's Avatar
markbett
Default Horsepower???
Does any one know how to calculate horsepower? The simplified version if possible.
Old Oct 17, 2005 | 01:57 PM
big_G's Avatar
big_G
Too many variables...take the Vette to a chassis dyno and find out.
Old Oct 17, 2005 | 02:03 PM
gerry72's Avatar
gerry72
The mathematical formula is HP = Tq x rpm over 5252. This has to be done on a dynomometer since you need a torque measurement.
There are other ways to calculate horsepower by speed measurements, but if you were wondering about your car, it's best to pay the money to put the car on a chassis dyno.
Old Oct 17, 2005 | 02:48 PM
Gordonm's Avatar
Gordonm
The horsepower was first used by James Watt during a business venture where his steam engines replaced horses. It was defined that a horse can lift 33,000 pounds force with a speed of 1 foot per minute: 33,000 ft·lbf·min−1.
Old Oct 17, 2005 | 03:13 PM
Buzzardz_vette's Avatar
Buzzardz_vette
That really kept it simple....
Old Oct 17, 2005 | 03:25 PM
gerry72's Avatar
gerry72
...33,000 pounds force with a speed of 1 foot per minute: 33,000 ft·lbf·min−1.
It's per second, but this part only unravels the what's so special about 5252, which no one really even cares about unless they're an engineer.
Old Oct 17, 2005 | 03:29 PM
ismithlj's Avatar
ismithlj
So why use a dyno. Just get yourself a 33,000 lb weight and a pulley.
Old Oct 17, 2005 | 03:40 PM
markbett's Avatar
markbett
Thanks you guys, I think I'll put it on a dyno. I'm so confused I don't even remember what day it is., what was that about a horse & pulleys, 33,000?
Old Oct 17, 2005 | 04:34 PM
Star79's Avatar
Star79
Here you can try this, it just takes weight and ET and gives you an "estimate", basically the same thing a G-Tech would give you after a 1/4 mile run. Should be within 15/20% either way, but there are too many variables (gearing, traction, etc etc etc) for it to be real accurate. Then again, I could guess mine within 20% without knowing much of anything...
http://javascript.internet.com/calcu...orsepower.html
Old Oct 17, 2005 | 04:53 PM
Gordonm's Avatar
Gordonm
Yes it is per minute not second. Here is the long version. They even have something in there about the Corvette!
How do you define horsepower? Ask a car enthusiast and most of the time you'll get a blank look, a shrug of the shoulders and maybe a guess along the lines of "What a horse can do!".
That answer begs the question: What horse? A thoroghbred race horse that can carry the small weight of a jockey with a lot of speed, or a working horse that can pull heavy loads albeit slowly? Obviously there is a more precise answer. Car manufacturers, despite their reputation for being creative regarding the horsepower ratings of their products for marketing reasons, require a more stable definition.
Horsepower is defined as work done over time. The exact definition of one horsepower is 33,000 lb.ft./minute. Put another way, if you were to lift 33,000 pounds one foot over a period of one minute, you would have been working at the rate of one horsepower. In this case, you'd have expended one horsepower-minute of energy.
Even more interesting is how the definition came to be. It was originated by James Watt, (1736-1819) the inventor of the steam engine and the man whose name has been immortalized by the definition of Watt as a unit of power. The next time you complain about the landlord using only 20 watt light bulbs in the hall, you are honoring the same man.
To help sell his steam engines, Watt needed a way of rating their capabilities. The engines were replacing horses, the usual source of industrial power of the day. The typical horse, attached to a mill that grinded corn or cut wood, walked a 24 foot diameter (about 75.4 feet circumference) circle. Watt calculated that the horse pulled with a force of 180 pounds, although how he came up with the figure is not known. Watt observed that a horse typically made 144 trips around the circle in an hour, or about 2.4 per minute. This meant that the horse traveled at a speed of 180.96 feet per minute. Watt rounded off the speed to 181 feet per minute and multiplied that by the 180 pounds of force the horse pulled (181 x 180) and came up with 32,580 ft.-lbs./minute. That was rounded off to 33,000 ft.-lbs./minute, the figure we use today.
Put into perspective, a healthy human can sustain about 0.1 horsepower. Most observers familiar with horses and their capabilities estimate that Watt was a bit optimistic; few horses could maintain that effort for long.
Although the standard for rating horsepower has been available for over 200 years, clever car manufacturers have found ways to change the ratings of their engines to suit their needs. During the famous horsepower wars of the 1960s, manufacturers could get higher figures by testing without auxiliary items such as alternators or even water pumps. High ratings backfired when insurance companies noticed them and started to charge more for what they saw as a higher risk. Manufacturers sometimes responded by listing lower horsepower figures, forcing enthusiasts to look at the magazine test reports to determine what was going on. In the early seventies the SAE (Society of Automotive Engineers) stepped in with standardized test procedures and the fiqures were more consistent.
Between 1922 and 1947, the Royal Automobile Club used a horsepower rating that was the basis for an automobile tax. The horsepower of an engine was determined by multiplying the square of the cylinder diameter in inches by the number of cylinders and then dividing that figure by 2.5. Using this dubious method, What we know of as a 385 horsepower motor found in the Z06 Corvette would be rated at only 48.67 hp!
There is a metric horsepower rating, although it is rarely used. The two methods are close, with one SAE horsepower equal to 1.0138697 metric horsepower.
One horsepower also equals 745.699 watts. This means that if you really want to confuse people, you could complain about the .02682 horsepower light bulb your landlord has in the hallway as opposed to the mundane 20 watt measurement.
Old Oct 18, 2005 | 06:35 AM
gerry72's Avatar
gerry72
You're right. What the hell was I thinking about? Beats me.
Old Oct 18, 2005 | 09:48 AM
markbett's Avatar
markbett
I would think that GM or any car manufacturer, has a formula to calculate horsepower that takes into account, cubic inches, exhaust type, alternator, water pump (as you suggested), tire size, car weight and anything attached to the engine that would suck power. I mean the manufacturers, wouldn't build the car and throw it on a dyno to test the horsepower, they should have it figured out long before they even build the car???
So I have a fuel injected 350 cubic inch engine, that's bored .4 over, no power steeering, no power brakes, no air, with Hooker sidepipes, , I have to believe (and it feels like) there's a lot of horsepower under the hood. any ideas???
Old Oct 18, 2005 | 09:57 AM
Fevre's Avatar
Fevre
They can put all the acc and smog/emission equipment on an eng and dyno it without putting it in a car, they do not use rear wheel horsepower for any stated hp numbers, they used to use gross which would be just what the eng put out without any acc or smog then switched to net in 1972 I believe. Today diff car companies use diff methods to rate so take the numbers you see with a grain of salt.
To Horsepower???
