? ? ? Tires
Old Oct 18, 2005 | 04:54 PM
whitesnake81's Avatar
whitesnake81
Default ? ? ? Tires
I want to keep 15X8 rims on my 81. I would like to know the largest tire you can run and not rub on the rear? What size tire came on the front from the factory?
THANKS!!!
Old Oct 18, 2005 | 06:10 PM
TonySinclair's Avatar
TonySinclair
Not sure of the factory size (G70's on '74), but I had 255/60-15's (front/rear) before I switched to 17's...
Old Oct 18, 2005 | 06:29 PM
TheKomoman's Avatar
TheKomoman
St Jude Donor '13
I run 255/60-15's front & rear on my 80. No rubs.
Old Oct 18, 2005 | 06:38 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
I saw this vette last weekend at the C3 Extravaganza in Bowling Green and he was running 295/50/15 on the rear. I did not check to see if the parking brake bracket had been moved. I should have, the 295 tires really look mean.
Old Oct 18, 2005 | 07:27 PM
Bill 81 F's Avatar
Bill 81 F
Cruising
I have had 245-60-15's on my 81 for years with no problems except there is not that much clearance for the rear exhaust pipes. Mine came new with 225-70-15's, which was one option. The other tire option offered was 255-60-15's so that size should not be a problem
Old Oct 18, 2005 | 07:33 PM
burgdob's Avatar
burgdob
225-70/15 was standard with 255-60/15 the option.
I run 255-60/15 on back and 235-60/15 on front.
Old Oct 18, 2005 | 07:55 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
You'll have to lower the rear slightly if you use a 295-50-15 tire, look at the photo above - there's a huge gap between tire and fender.
255-60-15 will fit without problems, at least on the rear axle. The front may require fender trimming.
I run 275-60-15 on the rear, the overall diameter is 1" bigger than 255-60 (28" vs 27") ... these tires are flexing a lot with the huge sidewall, 295-50 may be the better choice but you'll have to relocate the parking brake cable bracket, no way that tire fits with the bracket in the stock location.
Old Oct 23, 2005 | 01:43 PM
Islander90's Avatar
Islander90
how are you guys fitting these tires on your cars (other than the parking brake bracket thing)??? I have the stock 225-70r15s with factory wheels on my 77 and I got under the front and with the wheels at full turn, they're like half inch from the fender. just doesn't seem like wider tires would fit.
Old Oct 23, 2005 | 04:08 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
I think my '77 has 255/60/15 tires...but I'll have to check. If they are, that size has been there for more than 15 years now. No problems, whatever size they are, which is quite a bit wider than stock.
Old Oct 24, 2005 | 12:04 AM
rihwoods's Avatar
rihwoods
I ran 255-60-15's all around on my 78..had to trim wheel well flange on drivers side only (on rear side).
Old Oct 24, 2005 | 12:29 AM
Islander90's Avatar
Islander90
oh, another question on this subject; you guys talking about 255s have these rims too (pic is mid-polish):
i assume those only ever came in one size/backspacing, so if those run 255s without any problems, i'll definitely go with them instead
Old Oct 24, 2005 | 12:33 AM
rihwoods's Avatar
rihwoods
Same wheels I had with 255's mounted...no problems...the 255-60-15's were option tires on those wheels in 78 btw...
Old Oct 24, 2005 | 01:24 AM
W3EOS's Avatar
W3EOS
I have 255/60R15's all-around on my '79. Like was already noted, they were an available option that year.
To ? ? ? Tires
