will 4.5 work?
Old Oct 19, 2005 | 02:27 PM
Jclgodale3's Avatar
Jclgodale3
Default will 4.5 work?
Folks...found some 17x8 wheels I really like but they do not come with 4" backspacing. Only 4.5" backspacing. Will these work on my 71? What will the affects be to the position relative to the body and frame?
TKS
Old Oct 19, 2005 | 06:37 PM
Jclgodale3's Avatar
Jclgodale3
anyone?
Old Oct 19, 2005 | 06:44 PM
big_G's Avatar
big_G
It will hit, more than likely on the trailing arm and/or rear sway bar. A 1/4 in spacer may help. The fronts will probably be o.k.. G/L
Old Oct 20, 2005 | 01:16 AM
LiveandLetDrive's Avatar
LiveandLetDrive
4.5" bs and 17" wheel will hit in the back? Is that if you don't move the parking brake bracket?
-Chris
Old Oct 20, 2005 | 01:36 AM
Jclgodale3's Avatar
Jclgodale3
-Chris
Old Oct 20, 2005 | 09:28 AM
big_G's Avatar
big_G
I don't think the parking brake bracket will hit with a 17 in. wheel.
Old Oct 20, 2005 | 09:56 AM
LiveandLetDrive
I'm just suprised because I've heard of others on this forum using 4.5"bs and even 4.75" backspacing without offset trailing arms. It would definitely hit a sway bar though, you're right about that.
Old Oct 20, 2005 | 10:29 AM
big_G's Avatar
big_G
The tire size is the concern in the back. A 255 might clear the trailing arm...anything bigger will probably hit, but you shouldn't put anything bigger than 255 on a 8 in. rim anyways.
Old Oct 20, 2005 | 06:51 PM
Magnet's Avatar
Magnet
My 80 with 17" x 9.5" centerlines have a 5" back space. The tires fit good on the front, but on the back I needed a 3/8" spacer to clear the rear brake caliper....which was the cause for me to install
moroso 2 7/8" extended wheel studs. my $0.02
To will 4.5 work?
