There were some posts about people using RITZ dye to change the color of the belts.
I dont know what that will do to the integrity of the belts though. Does it affect or weaken the material in any way?
Are you going lighter or darker with your color choice. If you are going darker it will probably work. If it is lighter, then I dont know how you will change from a red color to a tan color or similar.
I've had a couple sets of seat belts rewebed over the years. A local auto interior upholster did the job in both cases. It was a simple matter since the stitching is easy to replicate and the sewing is well within the capability of any upholster's machines. A good job will also take the sewn-on labels off your old webs and properly sewn onto the new ones. The seat belt web is available in rolls to all upholsters.
The last ones I had done a month or so ago ran $20 per piece, or $40 per side for both the lap belt and the shoulder belt. Take the opportunity to lightly oil the retractors while you are at it. If you look at the retractors carefully, they are pretty simple devices.
I had Snake-Oyl do a set a few years ago and I remember them running much more....around a hundred dollars a side and it took a couple months to get back. That's what I remember, but I could be wrong on the price. I think it's best to call them a get a quote before sending them off.
kdf
i will either try the ritz dye, or buy aftermarket belts as my seats will now be sport seats with the shoulder harness holes in them. god my wife is gonna kill me. and kdf1986, i am changing from grey to doeskin, which is tan looking, ill try a spot to see if it works. thanks for the advice.
