Engein Combos
Old Oct 20, 2005 | 06:55 PM
Silver00V6Camaro's Avatar
Silver00V6Camaro
Default Engein Combos
Does anyone have a website or link to dynoed engein combos. I am still trying to figure out a good 400 hp/tq street motor for my vette to repair what bubba built. I am not removing the motor just need different intake, heads especially since they used the old 882s that were on the l48 and a different cam that does not require a 3000 stall. I have found some sites but I am still confused there are to many options at this point I need to keep it 2000 dollars or less.
Old Oct 20, 2005 | 06:59 PM
Gordonm's Avatar
Gordonm
http://ryanscarpage.50megs.com/combos1.html
Try this one
Old Oct 20, 2005 | 07:30 PM
Fevre's Avatar
Fevre
Originally Posted by Gordonm
Been a while since I read through those combo's, makes me wish I had an eng dyno and an unlimited access to engines
Old Oct 20, 2005 | 07:45 PM
Z-man's Avatar
Z-man
Good list. I clicked on the one link for God's suggestions 'cause I wanted to see what combinations he would suggest (I guess there weren't any).
Old Oct 20, 2005 | 08:44 PM
dboz's Avatar
dboz
http://www.dallasexportsales.com/SM383.htm
Old Oct 20, 2005 | 09:25 PM
Silver00V6Camaro
Well i took a look at that site and i am thinking about using trickflow heads. My block is bored over .30 and here is what i am thinking about using.
350 bored over 30
Lunati Voodoo Cam 60102
@050 219/227 lift .468"/.489"
Trick Flow 23 Degree Aluminum Cylinder Heads
Weiand Stealth Intake Manifold
Holley Street Avenger 770 cfm
Is this a good combo. what kind of numbers might i see with this combo. Can i still use the stock tq convert with this cam?
thanks
Old Oct 21, 2005 | 06:54 AM
C3Curves's Avatar
C3Curves
how much are you looking to spend? Some of the kits available out there such as Holley Systemax II kit take all the guesswork out... but may need to change converter with most of them.. Im goin that round...may cost me only 2000.. if my connections come thru
To Engein Combos
