Does this make sense?
Old Oct 23, 2005 | 01:39 AM
Sprzout's Avatar
Sprzout
Default Does this make sense?
This is what's printed on our new thermostat that we bought from Summit Racing, and is a Mr. Gasket Co. brand:
Does this make sense to anyone else as to why a thermostat, which is rated at the same temperature as the stock thermostat, would have this?
Is there something DIFFERENT about this thermostat that would ONLY qualify it for use on a race vehicle?
I wrote this to Mr. Gasket Co when I got it, but I haven't received a reply back; I can't see any reason for it.
I mean, thermostats aren't something that affects emissions, as far as I can tell...
Old Oct 23, 2005 | 02:15 AM
TonySinclair's Avatar
TonySinclair
I'm no expert, but...I believe the disclaimer is a "generic" label which is required to sell the product in Calif. (or elsewhere). So, instead of having different labels, they put one on all products, regardless of where they ship. I know of several other items that have disclaimers that do not apply (e.g. "NY Fire Marshal approved", "Miami-Dade Hurricane Approved")
That being said...the t-stat temp does affect emissions output. The longer a car takes to reach (optimal emission) operating temperature, the more pollution it spews. So, if you put a 160 t-stat in a car designed to run optimally with a 185 t-stat, you're technically messing with the emission controls.
Anyone who actually knows what they're talking about, please speak up...
Old Oct 23, 2005 | 07:21 AM
PhotoVette1's Avatar
PhotoVette1
Yes, changing the engine operating temperature changes the emission characteristics of the car and is just as illegal as removing the cats. Up to a $2500 fine (in theory).
I would never put in a 160F. Aside from other problems, a 160F wouldn't allow the EFE valve to open; the EFE valve opens at 180F coolant temperature. There's been plenty of discussion about various t-stat temps on this board.
If the thermostat needs to be replaced, install one with the same temperature rating as the original. Most cars and light trucks since 1971 require thermostats with 192 or 195 degree ratings. Using a cooler thermostat (160 or 180 degree) can increase fuel and oil consumption, ring wear and emissions. On newer vehicles with computerized engine controls, the wrong thermostat can cause major performance and emission problems if the engine fails to reach the proper operating temperature.
Old Oct 23, 2005 | 07:52 AM
rihwoods's Avatar
rihwoods
Whenever I make a phone order or online to Summit,I must acknowlege that disclaimer....
To Does this make sense?
