adding c4 and c5 wheels...I was thinking
Old Oct 25, 2005 | 01:47 PM
1982CorvetteDude's Avatar
1982CorvetteDude
Default adding c4 and c5 wheels...I was thinking
Since everyone that I have seen so far has used adapters to put later model wheels on thier c3's I was wondering......
Couldn't you have the C3 rotors redrilled for the correct bolt pattern for newer wheels or:
Use a set of c4 rotors? I didn't know if they were very similar in design to the C3's and maybe they would bolt up.
Or maybe you have to use thicker adapters anyways because of backspacing issues?
Thanks for anyone's input on why you can/or can not do this
Old Oct 25, 2005 | 01:49 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
that's why - the bolt pattern fits, it's only a backspacing issue.
Old Oct 25, 2005 | 03:09 PM
Yellow73SB's Avatar
Yellow73SB
St. Jude Donor '07
Old Oct 25, 2005 | 04:33 PM
1982CorvetteDude
I was afraid of that, I was looking at some polished 17" Z06 Replicas on Ebay for $429 + shipping.
I'm still going to go that route with the wheels and just buy adapters to make it work.
Thanks everyone
Dennis
Old Oct 26, 2005 | 08:28 PM
Techno's Avatar
Techno
The bolt pattern don't fit... well it does but the center hole don't . The hub hole is a smidgen larger on the C3s than the C5s.
If you have the money you can get correct wheels for your car that don't use adapters. Figure on I think $500 for the adapters.
You'll have 1 grand in wheels, not sure what the others cost. That hot rod show guy.
Old Oct 27, 2005 | 02:36 AM
stickboy's Avatar
stickboy
if you spend $500 on wheels and $500 on adapters you can buy custom wheels for almost the same price
Old Oct 27, 2005 | 06:46 AM
1982CorvetteDude
Thanks guys,
Thats what I'm finding out, is that basically the cheapest "factory" C4 and C5 17" polished wheels are running around $560 shipped that I'm looking at.
Adapters are around $130 for four on ebay (if I went that route), but you really don't know what your getting.
^ So thats around $700ish for all that,
then I found some direct bolt on chrome american racing 17" wheels for $769 shipped. (ebay)
crusinchrome.com has the z06 motorsport 17" chrome replica's that are direct bolt on with some moving of the parking brake cable bracket for $1000 shipped.
I think I am goiing to go the direct bolt on route. Way easier.
Old Nov 6, 2005 | 09:01 AM
1982CorvetteDude
Another question,
I found a ebay webpage that has these wheels
http://cgi.ebay.com/ebaymotors/17x8-...temZ8011872969
It says "This wheel size has a 0mm offset (4.50" backspacing) and is a direct fit for 1967-1992 Chevrolet Camaro and Pontiac Firebird."
Fron the looks of it the offset and possibly the backspacing is matched to the original aluminum wheels on my 82, but it has a 5 x 4.75" bolt pattern, it was mentioned above that the hubs are larger on the 5 x 5" bolt pattern. So it may not work?
I didn't know if there was something different on the early camaros that would match up to the c3's.
I emailed the seller and inquired if they could get a pattern to match my vette but haven't heard back yet, But i do know they have the Iroc chrome replicas in 16 x 8 - 20 x 8 in the 5 x 5" bolt pattern so they may have others hopefully, I like thier prices.
Old Nov 6, 2005 | 02:37 PM
Techno's Avatar
Techno
I don't know what C5 wagon wheels go for but theres gotta be someone with 4 boxes sitting in their basement willing to clear space for less than $125 per wheel.
Hmm my brother was... they were FREE!
I understand they don't want them and are very cheap, so cheap they don't bother selling them. These are the rather ugly ones.
The other C5 wheel forgot its name, infinity or ? it has the triangular shaped spokes. Still are replaced and might be a better deal than the correct rims.
If you compare proper rims to C5s beware of escallating cost. Almost the same might be 1200 or 1600 or... while with C5s your starting cost is still the adapters, the rims are an unknown.
The big big advantage to proper rims is you get to choose the style.
Coddingtons? I think that was the name.
Old Nov 6, 2005 | 03:04 PM
SteveG75's Avatar
SteveG75
Another question,
63-82 Corvettes are a 5 x 4.75" bolt pattern. 5x5 is for fullsize cars, trucks. If you get 5x5 wheels, they will not fit.
Old Nov 6, 2005 | 04:37 PM
1982CorvetteDude
I'm glad to hear that, I've looked at a few sites that listed specs and they stated that the C3's were 5 x 5 and went back to 5 x 4 3/4 in 1984. If thats the case the ebay wheels I was looking at should fit with no problem.
Old Nov 6, 2005 | 10:28 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
It's not only the backspacing that can give you problems, the back side of the spokes may not clear the calippers. Less offset (less backspacing) only changes the location of the spokes relative to the rim, it does not change the distance from mounting surface to the spokes. A spacer/adapter however does this, that's one reason why I like to use these. there's a seller on ebay who sells good quality spacers (completevalue). I bought his spacers and they're great.
To adding c4 and c5 wheels...I was thinking
