75 A/C fan switch
Old Oct 26, 2005 | 12:09 PM
jd1a's Avatar
jd1a
Default 75 A/C fan switch
I need to replace the fan control switch. I've had the cover plate off and can't pull the wire / vacuum line harness back far enough to remove the switch. What am I missing, I don't want to break the old vacuum lines. How do I do it?
Old Oct 27, 2005 | 08:26 AM
jimvette999's Avatar
jimvette999
remove small hex head screw retaining vacuum bundle to controller, then remove vacuum bundle from controller and hopefully you'd get some slack
Jim
Old Oct 27, 2005 | 11:15 AM
jd1a's Avatar
jd1a
I can't even get that far. I've had the cover off and the controler will only move an inch. Then it starts to get very tight. I looked from the dash side of the console and I can't get my hand in there to help.
To 75 A/C fan switch
