assembly manual vs. shop manual
Old Oct 28, 2005 | 03:27 AM
rick1500's Avatar
rick1500
Default assembly manual vs. shop manual
I'm restoring my 70' coupe and was wondering if it makes sense to get both the factory assembly manual and the shop manual w/ supplement. I'm guessing the shop manual has more of a "how to" feel and the assembly manual is mostly diagrams and part numbers. I'm planning on getting both unless someone tells me that I'd be fine with just one or the other.
http://www.gregsonline.com/eshop/Corvette/7130.htm
http://www.gregsonline.com/eshop/Shop_Manuals/70PSM.htm
My Haynes manual isn't very helpful. I'm at the point in the restoration where I've completely disassembled the car (frame off), have everything sandblasted/painted/powder coated, new bushings, bearings, etc. from Van Steel, and am starting the re-assembly. Thanks,
Rick
Old Oct 28, 2005 | 05:04 AM
hunt4cleanair's Avatar
hunt4cleanair
Rick
Rick...you're right on with your assessment of shop manual vs assembly manual...it makes perfect sense to get both. They compliment one another and you're at a point where both will be helpful. I agree Hayness is limited and not helpful in comparison to the other two manuals.
Old Oct 28, 2005 | 08:52 AM
Edzred72's Avatar
Edzred72
Definitly buy both. One helps you mechanically...the other helps with assembly.
Eddie
Old Oct 28, 2005 | 09:28 AM
page62's Avatar
page62
You can find shop manuals on ebay pretty cheap. I see them at swap meets all the time, too. Highly recommended.
Old Oct 28, 2005 | 11:09 AM
Milest's Avatar
Milest
I would get them both. Very useful and full of information.
Old Oct 28, 2005 | 11:16 AM
NHvette's Avatar
NHvette
Definitely get the AIM, which shows specific things for your year.
Plus, it doesn't break the bank at $20 or so.
The shop manual is great, more so if you have less experience
working on cars.
I only have the Haynes manual ... for torque values, etc.
The price of the shop manual makes you think about that purchase.
I used both last night, debugging my new horns. The Haynes manual
has two sentences ... jump the horn to test. If not working,
renew the horn relay. "Great, that was helpful ... no picture, etc"
Well, it turns out the Haynes manual was spot-on my problem.
The AIM is what showed me where to look for the relay.
In 75, it is above the fuse panel.
Old Oct 28, 2005 | 11:21 AM
rick1500's Avatar
rick1500
Thanks guys, I'm getting both. I'll keep you posted!
Rick
Old Oct 28, 2005 | 04:53 PM
Shrike's Avatar
Shrike
Just out of curiosity, does anyone know if the repro shop manuals are bound (like an actual book) or simply loose paper?
Old Oct 28, 2005 | 06:38 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
No clue. I picked up an original from eBay for far less than the repop.
Old Oct 29, 2005 | 10:35 AM
Milest's Avatar
Milest
The assembly manual was loose sheets that I placed in a three ring binder. The shop manual was bound.
Old Oct 30, 2005 | 09:29 AM
aocm77's Avatar
aocm77
Default Manual
My assy manual was loose sheets and just put it in a binder. Good price on e-bay.
To assembly manual vs. shop manual
