Motor mount ???
Old Oct 31, 2005 | 12:51 PM
Chopper Larry's Avatar
Chopper Larry
Default Motor mount ???
DUmb question....how da ya know if motor mount(s) are needed; all of a sudden I'm getting a lot of a vibration like motion from the front of the car at idle. It's a L-48, so it's not a huge cam, but feels like it; or feels like a bad miss; but the car seems to run pretty good.
Old Oct 31, 2005 | 12:58 PM
TheKomoman's Avatar
TheKomoman
St Jude Donor '13
Best thing to do is get up under and look at them. If they're split badly enough to cause the motor to jerk around there should be visible evidence. You could also watch the motor while somebody stomps on the gas for you, but the "how much" it moves is rather subjective.
If they're the original motor mounts since it's a fairly inexpensive and easy thing to do you might just want to replace them. Better safe...
Old Oct 31, 2005 | 01:07 PM
G dad's Avatar
G dad
From: THE OLDER I GET THE BETTER I WAS! NORTHERN ONTARIO
You might want to check the Transmission mount as well.
Old Oct 31, 2005 | 01:16 PM
Sprzout's Avatar
Sprzout
If they look like they're torn or look compressed, it's probably time to replace them.
They can be replaced with polyurethane mounts, which might be a good idea if you've got a high torque engine; otherwise you might just tear them out again by putting a good load on it.
It's a relatively simple install; put a jack underneath it with a 2x4 on it to jack up the engine a bit when you go to take off the mounts; that should give you enough lift amount and enough surface area to get the engine up. The wood will also act a bit like a cushion so you won't mess up the oil pan when lifting.
Old Oct 31, 2005 | 04:15 PM
TheKomoman's Avatar
TheKomoman
St Jude Donor '13
I meant to mention that. The tranny mount on my 80 was separated. That explained the big thump though!
Old Nov 1, 2005 | 04:20 AM
Buffalo Dude's Avatar
Buffalo Dude
St. Jude Donor '07
I did this over summer!
Pretty much you power brake with the hood open and see how much the engine moves. If the mount is split, it's VERY obvious. I do like the poly mounts though. Very shiny and should last a whole lot longer than the rubber.
Old Nov 1, 2005 | 05:32 PM
gliot1's Avatar
gliot1
St. Jude Donor '12-'13
Another method to check we used to do years ago is to put the car in drive with the brake on and mildly brake torque it. You will see the engine twist up if the mounts are broke.
Old Nov 1, 2005 | 09:43 PM
Sprzout's Avatar
Sprzout
Something I forgot to mention with Poly bushings:
Because the poly bushings are more firm, if you install them you will notice a little bit of vibration at idle, or at RPM just above idle (ie takeoff from a dead stop).
However, that takeoff is going to feel more solid with those polyurethane bushings, because more of the energy is being transferred into the frame for resistance.
To Motor mount ???
