is this possible
Old Oct 31, 2005 | 06:28 PM
71redskin's Avatar
71redskin
Default is this possible
i bought a used cd player and instaled it in my 71... i posted about not having any bass, but i guess it'd more appropiate to say the rear speakers have a distorted sound....checked polarity and all checked out ok...hooked up a 200 watts amp/equalizer last night and got a louder distortion. b4 i try hooking the rear speakers to the front channel is it possible my rear channels could be blown
Old Oct 31, 2005 | 06:33 PM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
Sounds to me that the first thing to look at would be wiring phase. Make sure you have + to + and - to - all the way around.
Old Oct 31, 2005 | 06:36 PM
mayberg's Avatar
mayberg
Is there enough of an enclosure for the bass to do its thing?
Old Oct 31, 2005 | 07:20 PM
TheKomoman's Avatar
TheKomoman
St Jude Donor '13
You've tested them using two different amps it sounds like, the head unit and a separate amp. My guess would be it's the speakers. A reverse in polarity/phase will not usually produce distortion, it will just make for an.... interesting equalization curve.
Old Oct 31, 2005 | 07:25 PM
mandm1200's Avatar
mandm1200
I am no stereo expert, but having the +/- backwards would affect the phase and should not create distortion.
Best way to determine the problem may be by swapping parts. Start with a known good CD player or head unit (or anything that has audio outputs you can jack into the amp).
Old Oct 31, 2005 | 07:42 PM
BUGGSY1970's Avatar
BUGGSY1970
Maybe that's why it was sold used. First owner may have burnt the head so he got rid of it. I would take it back and get a new unit. You have already wasted more time than it is worth.
Old Oct 31, 2005 | 07:44 PM
71redskin's Avatar
71redskin
the reason i asked if the rear channels on the head unit might be bad is because i put in new 4x6 speakers in the dash and they sound fine... my next alternative is to hook the rear speakers to the front channels and see if the sound clears up...opinons pleez
To is this possible
