speedometer
Old Nov 11, 2005 | 03:38 PM
LABEL's Avatar
LABEL
Default speedometer
I removed the instrument cluster that contains the tach and speedometer on my 82. I replaced a burned out bulb. To remove I disconnected and later reconnected the speedometer cable. After reassembling the cluster I observed that the speedometer needle is at the far clockwise position indicating 80+ mph. Any ideas as to how it ended up here? I not aware of how it could have gotten in this position or how to get it back to 0 mph.
Old Nov 12, 2005 | 09:53 AM
LABEL's Avatar
LABEL
Default needle doesn't move
I pulled the lense cover off to see if I can move the needle back where it belongs and it feels like it will break something if I try and move it back counterclockwise. Anybody got any experience with this?
Old Nov 12, 2005 | 04:35 PM
palazzopl's Avatar
palazzopl
try to disconnect the cable from the cruise control on the left fender well.. the cable might be jammed
Old Nov 12, 2005 | 04:56 PM
LABEL's Avatar
LABEL
Default cable
My cable goes to the transmission. I have disconnected it. What ever is going on is happening to the speedo. I haven't driven it with the cable connected.
To speedometer
