You put the bottle where the spare tire carrier is, thats cool. Are you on a microswitch, or push button?
Microswitch at WOT on throttle body. Remote bottle valve a must since can't just reach behind the seat. Fuel pressure safety switch also good idea. Don't forget the purge valve. Mine purge right up by the windshield on each side and spray up along the pillar post. Ran 1/8" steel lines from a tee on the firewall....all concealed. Push button purge on the Hurst shifter handle. Let me know if I can be of any assistance to ya.
"This largely depends on the type of nitrous kit and jetting used. For example, a 125 HP Power Shot kit with a standard 10 lb. capacity bottle will usually offer up to 7 to 10 full quarter-mile passes. For power levels of 250 HP, 3 to 5 full quarter-mile passes may be expected. If nitrous is only used in 2nd and 3rd gears, the number of runs will be more."
