Vette Hauling Checklist
Old Nov 17, 2005 | 07:28 PM
C3 RV's Avatar
C3 RV
St. Jude Donor '15
Default Vette Hauling Checklist
It looks like I'll be picking up my vette using my Sierra and a rented open car trailer next week. I figure I'll need:
- 4 10K rachet straps
- Assortment of boards in case the ramp is too steep.
- Jumper cables
- Hydraulic jack
- Trailer plug adapter
- Tools including lug rachet and cheater bar.
Anything else you can think of?
Old Nov 17, 2005 | 08:17 PM
Avette4me's Avatar
Avette4me
Cruise-In VIII Veteran
i rented a u-haul when i left IA - car loaded fine, fit well, and the tire hold down did a fine job..
Old Nov 17, 2005 | 08:23 PM
C3 RV's Avatar
C3 RV
St. Jude Donor '15
I'm crossing the state line and U-Haul won't rent to me except one-way. I've also noticed that most all of the U-Haul units are beat to death. I found a local hardware store that rents nicer trailers, cheaper.
Old Nov 17, 2005 | 08:54 PM
Glensgages's Avatar
Glensgages
- Jumper cables
- Hydraulic jack
* A spare tire that'll fit the trailer would be a good thing ( a loaner from a buddy ? ).....
* various lengths of chain, and various connectors, like screw-pin clevis.....
* a few blocks of wood/railroad ties, to serve as wheel-chocks.....
* flares, flash-lights, or various road-side emergency tools.....
* electrical tools, and spare light-bulbs for the trailer..... in-case the trailer needs re-wired while on the road.....
Old Nov 17, 2005 | 10:09 PM
David Ey's Avatar
David Ey
A word of caution about those U-Haul car trailers.
The wrap around the tire tie downs Will Not Stay On on the larger tires. They will slip right off and allow auto to move around. I know first hand.
Old Nov 17, 2005 | 11:19 PM
ZL1powr's Avatar
ZL1powr
- Jumper cables
- Hydraulic jack
On the 10K rachet straps, be sure to use the kind that have a locking hook not just an open hook. If the straps stretch a little as you hit bumps (and they will) they can come completely loose if the hooks are open (ask me how I know).
Old Nov 18, 2005 | 06:27 AM
guppie's Avatar
guppie
St. Jude Donor '08
A heavy duty come-along wouldn't hurt to have just in case it won't run
Old Nov 18, 2005 | 07:53 AM
C3 RV's Avatar
C3 RV
St. Jude Donor '15
Thanks for the good suggestions. The trailers have a spare, but I have to call whether the left fender folds down. If not, I may have to make a nascar exit. Another forum suggested a spare fuse for the trailer circuit. I'll have to check my supply of spare fuses or buy another. A come-along and bridle is a great idea - but I really shouldn't need it since the car ran great last Friday.
Old Nov 18, 2005 | 01:23 PM
Patrick73's Avatar
Patrick73
Air tank with air in it! Great for those low tires or slow tire leaks that develop as you drive. Excellent idea above re wheel chocks and boards for ramp entry--there have been times when I needed both items.
Old Nov 18, 2005 | 02:08 PM
Scottys78's Avatar
Scottys78
good luck and drive slow
To Vette Hauling Checklist
