smog removal
Old Nov 17, 2005 | 10:57 PM
driver68's Avatar
driver68
Default smog removal
removing all the smog stuff off the '72 I just bought. got the pump off, am having trouble getting the nuts off the manifolds, as they are almost "rounding off" as i try to loosen them. any ideas? i would prefer not to cut the tubes so that I have them for when i eventually sell it.
Old Nov 17, 2005 | 11:06 PM
jclit's Avatar
jclit
Try soaking them with PB Blaster, it works very good for me.
Old Nov 17, 2005 | 11:55 PM
Aflac's Avatar
Aflac
Cruise-In 5, 6 & 10 Veteran
St. Jude Donor '09
take a torch and heat the manifold until it is cherry red and go from there..they should back out then..
Old Nov 18, 2005 | 02:06 AM
memLT-1's Avatar
memLT-1
Keep me in mind when you decide to sell the smog equipment.Thanks
Old Nov 18, 2005 | 08:09 AM
MILO's Avatar
MILO
After soaking with soem PB Blaster, try banging on a slightly smaller metric socket, it may give you enough bite to get it off.
Old Nov 18, 2005 | 09:22 AM
stingr69's Avatar
stingr69
Use a torch and PB Blaster along with a vise grip. Back and forth should get them off. Don't clamp down too tight as the nuts are hollow.
-Mark.
Old Nov 18, 2005 | 09:36 AM
gq82's Avatar
gq82
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
That smog equpt will bring big $ on ebay.....or you may want to save it for the next guy.
Old Nov 18, 2005 | 09:38 AM
vettfixr's Avatar
vettfixr
This is a little off topic but something I remembered from back in my smog removal attempt days. I had problems removing the bolts that were used to plug the holes for the smog tubes. Naturally the threads got boogered and I wanted to tap them to straighten them out. I found that they were not NPT threads but SPT. NPT threads are tapered pipe threads whereas SPT are straight pipe threads of the type you see on lamps. It took a while to find the appropriate tap but I eventually got the threads straightened out and plugged. After that I ran the stock manifolds until I had other problems with them and then replaced them with pre-smog rams horns. Later I ditched all that for a set of headers and haven't looked back since. Just a little trivia for ya.
Old Nov 18, 2005 | 10:21 AM
gq82's Avatar
gq82
My first new car was a 67 Camaro. I also ditched the smog equpt but if I remember correctly I went to a plumbing supply store and bought brass plugs for my exhaust manifold....they fit like a champ...no problems.
Old Nov 18, 2005 | 10:42 AM
kdf1986's Avatar
kdf1986
From other peoples advice and comment on this same topic, the common answer was using PB blaster and letting it soak for DAYS.
kdf
To smog removal
