To remove the console you need to take off the side panels and center cluster. Start with the side panels. Then the center cluster...watch for the two bolts underneath that attach the center cluster to the console...most miss then and break the console. there are also two bolts at the rear of the console. You also need to unscrew your ball on the shifter.
Actually if yours is under the console you may be able to get at it by just removing the side panels.
Mine by the way is in the passengerside storage compartment under the tray.
