Crate Engine HP
Old Nov 18, 2005 | 01:13 PM
TXredc3's Avatar
TXredc3
Default Crate Engine HP
Is the horsepower for crate engines rated at net or gross?
Old Nov 18, 2005 | 01:47 PM
rihwoods's Avatar
rihwoods
Gross at flywheel....at least ones I've seen advertised..
Old Nov 18, 2005 | 01:50 PM
page62's Avatar
page62
Old Nov 18, 2005 | 02:01 PM
Z-man's Avatar
Z-man
It always has to be gross at flywheel. They have no way of knowing what car the engine will be installed.
Old Nov 18, 2005 | 02:06 PM
AGVI's Avatar
AGVI
Canadian Events Coordinator
true
Old Nov 18, 2005 | 03:27 PM
TXredc3's Avatar
TXredc3
So, let me see if I got this straight. I have a 74 stock L-48. Think the HP is 195. I've been told this is a net hp number. I'm contemplating buying a ZZ4 that puts out 355 hp. Are you telling me that once I get the new engine in the car, it's going to be less than 355? Something like 80% of the gross number.......284??? If true, then I'll keep my 4 grand and buy bolt-ons for 2 grand to get up to the 284 hp. Let me know if I'm understanding this correctly.
Old Nov 18, 2005 | 04:40 PM
Localbulldog's Avatar
Localbulldog
Old Nov 18, 2005 | 10:30 PM
steves_77vette's Avatar
steves_77vette
You are most likely correct.....for the singel number of HP. However, you need to look at the broader picture of low end torque, etc to get something that gives you the "scalded dog" feeling you're probably looking for.
Old Nov 18, 2005 | 10:36 PM
big_G's Avatar
big_G
That beign said, the ZZ4 won't make your 'vette a scalded dog. The ZZ4 Fast-burn 385, now that's a different story...
Old Nov 19, 2005 | 09:50 AM
BrentDev's Avatar
BrentDev
How does a Fast Burn 385 (only 20 more HP net) make it that much more of a scalded dog?
As for the original question - all HP is always measured at the flywheel (nowadays).
For example - a 2005 ZO6 is 405 HP gross, but when you measure it at the rear wheels, it is somewhat less.
Not sure on the C5 numbers, but I remember for a C4 the drivetrain loss for a ZF6 was somewhere around 17-18%.
Hope this helps.
Old Nov 19, 2005 | 10:57 AM
big_G's Avatar
big_G
The heads used on the Fast burn ZZ4 are much better, and I've installed both. There is a bigger difference than you would think. I was never impressed with the base ZZ4, I think the h.p. numbers are optomistic. One thing you can't do with these engines is dog 'em down with lazy rear gears....
Old Nov 19, 2005 | 11:14 AM
PRNDL's Avatar
PRNDL
Hope this helps.
sorry, doesn't help! You are adding to the confusion.
When you buy a car today, hp is given as NET. A C6 ZO6 (is that 2005?) is now 505 NET hp. The 2003 ZO6 was 405 NET hp.
Back to the original question: Most crate engines are listed as gross hp. So the ZZ502 is 502 gross hp, and the ZZ4 is gross hp. These are crate engines that were never installed in new cars.
But there is an exception!! I have noticed that many original equipment engines are also available as crate engines. The LS6 (2004 ZO6 engine) is available as a crate engine. It is still listed as 405 hp, which is the net rating of the engine installed in a new ZO6.
So at this point I am pretty sure that there is a distinct difference between how crate engines are rated, depending on whether the engine is also used as original equipment (in which case it may be rated net hp).
If we need to review the differences between, gross, net, and rwhp someone go for it, I'm not gonna do it.
So the LS6 crate engine rated at 405 hp, which we know is the NET rating of a 2004 ZO6, is probably putting out more hp than a crate 454 engine rated at 425 hp, which is a GROSS rating.
Old Nov 19, 2005 | 12:12 PM
BrentDev's Avatar
BrentDev
Hmmmmm....I am not sure.
Isnt "NET" what is left over after all drivetrain losses?
Just like a "NET" gain or loss after taxes when talking about financial transactions?
The 405 on a LS6 is at the flywheel. NET to me would be more in tune with RWHP.
Although.....now that I think about it.....
GROSS should be what a bare engine is without all the extra accessories (AC, Alternator, Power Steering)
NET maybe is what it is at the flywheel for an engine with accessories.
RWHP is measured on a chassis dyno and adds in the drivetrain and potential full restrictive exhaust losses.
Seriously not trying to confuse people. Although you now got me confused.
Old Nov 19, 2005 | 03:49 PM
PRNDL's Avatar
PRNDL
Yes, you got it straightened out at the end of your post. We have had many discussions on this topic, but my additonal .02 which the discussion does not often get to, is that although the typical crate engine is rated gross hp (because noone knows how it will be used and what accessories it will be hooked up to) I have noticed that when LS6 or LS2 or LT1 engines are sold in crate form they are listed as the same hp that they are advertised when they come in a car, which is net hp. I have added my notes to your quote below:
correct! gross hp ratings were used prior to 1971. In 1971 they used both gross and net.
correct! This produced significantly lower numbers. The 1971 LS-6 was rated at 425 hp GROSS, but only 325 NET !!!!
correct! Manufacturers have never given or used RWHP ratings. So , hypothetically, my 1968 L-36 was rated at 390 gross hp. This might have been 300 NET hp and maybe on a dyno would have shown 250 rwhp. Some bigblock, huh? So the typical 350 gross hp crate engine might only give you 250 at the rear wheels, depending on accessories, exhaust and drivetrain
Old Nov 19, 2005 | 09:11 PM
redc3's Avatar
redc3
he's from jersey
To Crate Engine HP
