Front Coil Spring Replacement
Old Nov 21, 2005 | 04:31 PM
rondo73's Avatar
rondo73
Default Front Coil Spring Replacement
I am looking for advice on front coil spring replacement. I recently upgraded the rear suspension with composite spring, bushings, shock mounts and adjustable struts.
My question is how do you know when front coils need to be upgraded/replaced? My '73 has original springs and I don't know whether to replace them or not. I plan to rebuild the front end (bushings, tie-rods, ball joints, etc.) but am unsure what to do about the springs. Any help or suggestions appreciated.
Old Nov 21, 2005 | 05:12 PM
Gordonm's Avatar
Gordonm
If they are original springs they are probably sagging a bit by now. Springs are cheap. While you have the front end apart do the springs.
Old Nov 21, 2005 | 07:19 PM
73jst4fun's Avatar
73jst4fun
VP & Products can advise you on your front end rebuild, I put 460's in the front of my 73 and they have been fine. If they are origionals like mine were they will just fall out and are easy to replace and cut for the height your looking for....
Old Nov 21, 2005 | 09:45 PM
rondo73's Avatar
rondo73
I think I will go with the 460's. Thanks!
Old Nov 21, 2005 | 09:48 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
use the search function and search for "ride height" , "coil springs", "springs" a.s.o.....
depending on your desired ride height you might want to get the 550s from VBP
To Front Coil Spring Replacement
