Sound deadener...
Old Nov 22, 2005 | 12:53 AM
79VetOwner's Avatar
79VetOwner
Default Sound deadener...
I have pulled the interior out if my new Vet and found some torn up pieces of sound deadener under the carpet. I was thinking about putting new stuff in but using the spray this time. Any opinions??
Old Nov 22, 2005 | 04:20 AM
rosslato's Avatar
rosslato
http://www.insulation4less.com/highr_FfmF.asp
this is what i used to do mine. others use reflectix(home depot) and others use dynamat(more xpensive). i used 3M spray to glue it down and aluminum tape for the seams, then i sprayed 3M on the foil to attach the carpet(figure it'll be 10yrs or more before i need a new carpet). i didn't put the jute on top of the foil, some of us do and some don't. i have sidepipes so i don't get cabin heat.
Old Nov 22, 2005 | 09:36 AM
Robd's Avatar
Robd
After seeing your install on this I bought some from insulation4less as well. Very quick shipment I must say. Hopefully I will be installing this weekend.
Old Nov 22, 2005 | 10:23 AM
texaswilkins's Avatar
texaswilkins
I put a similar material in mine when I had the interior out. Make sure you get under the console bits and up under the back window. It really made a difference on interior heat and sound levels.
Bill
Old Nov 22, 2005 | 11:01 AM
Robd's Avatar
Robd
thanks for the intel, and its nice to know that it will make a difference. I am sure it will make a big difference for me. my carpet was just laying on fiberglass.
Old Nov 22, 2005 | 11:19 AM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
I did the same thing but w/Reflectix. Helped my cabin heat problem a lot but didn't deaden sound at all. I wish I knew about that stuff you used! Looks like reflectix.
Old Nov 22, 2005 | 12:07 PM
rosslato's Avatar
rosslato
it's very similar to reflectix, same thickness w/insulation for less supposedly being better for sound and heat. both being easy to shape and install
Old Nov 22, 2005 | 12:19 PM
79VetOwner's Avatar
79VetOwner
Default Thank you
Thank you for the info on that insul. I will look into it some more. Looks like you did a great job on it too.
Old Nov 22, 2005 | 01:19 PM
MEGALADON's Avatar
MEGALADON
From: WAY DEEP INSIDE AMERICO,YES YOU LIVE HERE TO!! TX
If money is not an issue, use DYNAMAT for sound deadening and
use TACMAT on top for heat.
I still have a ways to go
Old Nov 22, 2005 | 01:46 PM
Robd's Avatar
Robd
I didnt want to pay for the Dynamat but I agree it is the way to go for sound deadening.
Old Nov 22, 2005 | 06:18 PM
davidm_comp's Avatar
davidm_comp
I used the stuff from b-quiet.com in combination with reflectex from home depot and have nothing but good to say about the combo....
David
Old Nov 22, 2005 | 08:19 PM
LIQUIDDRAGON's Avatar
LIQUIDDRAGON
i like my dynamat install.
Old Nov 27, 2005 | 03:09 PM
bs82vette's Avatar
bs82vette
Three layers thick "Brown Bread" $100
Old Dec 3, 2005 | 09:56 AM
kb2fzq's Avatar
kb2fzq
Check this:
https://www.corvetteforum.com/techti...=241&TopicID=3
Old Dec 3, 2005 | 10:06 AM
kaiserbud's Avatar
kaiserbud
I used cool car ceramic (black paint with ceramic coated beads) in my interior. I have yet to reinstall my interior, but I hope to have time soon.
Has anyone tried the stuff from DEI? http://www.streetrodstuff.com/Products/1801/
Old Dec 3, 2005 | 10:08 AM
kaiserbud's Avatar
kaiserbud
That Brown Bread is a product of B-Quiet/ It appears to be for sound insulation only. They have a comparison chart which is nice - wish they all did this....
http://www.b-quiet.com/compare.html
This comparison by Dynamat Xtreme indicates better sound deadening at temps less than 86 degrees - but that's pretty much a winter day here in south Texas. http://www.dynamat.com/sound_dbate_X...comparison.htm
Although this opened my interest for sound deadening, my main goal is heat deflection.
Old Dec 3, 2005 | 12:56 PM
LiveandLetDrive's Avatar
LiveandLetDrive
Interesting comparison:
http://www.sounddeadenershowdown.com/
To Sound deadener...
