For all you painters out there, I am getting ready to start stripping the vette and I have read a few posts where everyone says to strip and then use lacquer thinner to clean the fiberglass and neutralize the stripper.
Well, I have a gallon of acetone from cleaning the gas tank and I have plenty of mineral spirits. Will all of these do the same thing or should I stick to the lacqure thinner?
Stick with lacquer thinner. Mineral spirits will leave a residue and definitely don't use acetone - it's the thinner in fiberglass. I've used it to remove fiberglass from parts before when the resin dripped on them.
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
when i paint cars...not often about 5 so far i have always used the "system" approach and only used the cleaners,primers, reducers, thinners etc that were made by the same company as the final paint....i wanted to ensure compatibility
If you use water soluble paint remover, then hot water and soap will remove the residue, if oil based remover, then denatured alcohol or lacquer thinner will do the job.
Use lacquer thinner. Acetone dries too quickly to do a good job of cleaning. Acetone won't hurt fiberglass after its cured. It's only a thinner for the uncured resins. Mineral spirits won't do a thing but make a mess and leave residue. I have used mineral spirits for cleaning off undercoating but it won't cut auto paint--even paint that has been softened with paint stripper.
STOP STOP STOP!!!! Lacquer thinner is also a carbon-based petroleum product. It will leave a film just like mineral spirits will. Unless your paint products specifically call for lacquer thinner, use an alcohol-based solvent for wiping the surface clean, i.e. denatured alcohol (not rubbing).
Go with the laquer thinner the flash rate is higher than mineral sprits and won't leave a film behind, The denatured alcohol will evaporate to quickly.......But if you already have it you can use it, you'll just use more.
When you take your car in for paint your painter will use prepsol on the car prior to priming so don't worry what you use to clean up the car after stripping.
Are you sure? I've removed cured fiberglass resin from metal components after it was on there for months using only Acetone (and not rubbing all that hard). Not saying it would hurt the factory stuff, but I would be cautious.
