New Hooker Sidemount headers install spark plug wire problem need some help.
Old Nov 23, 2005 | 12:06 PM
buffed1978's Avatar
buffed1978
Default New Hooker Sidemount headers install spark plug wire problem need some help.
I just installed my new Chrome Hooker Sidemount headers on my 1978 vette 350.The only problem that I have is on the drivers side front spark plug wire nearest the front of the engine I have no clearance for my spark plug wire it is touching the header when you push it on the plug as far as it will go I have 90 deg spark plug ends.I could by some of thoes spark plug wire heat shields that you pull over the wire dont realy like the looks of them so I was woundering if any of you guys had this problem with these headers and what you did to correct it.If you have any pictures of your engine with these hraders on that would help also thanks
Old Nov 23, 2005 | 12:27 PM
SteveG75's Avatar
SteveG75
Depends on the heads and plugs.
Mine are tight but do not touch. I have Edelbrock RPM heads and am using Champion RC12YC plugs which are a little shorter than stock. There are shorter plugs but there but you have to do some digging.
Old Nov 23, 2005 | 01:00 PM
1979toy's Avatar
1979toy
Run the wire past the header on top of the valve cover and then go in from the front side. The wire should be away from the header then.
Old Nov 23, 2005 | 01:56 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
Yup... that's what i had to do. PM me if you need to see a photo and I'll post it once I get home tonight...
Old Nov 23, 2005 | 06:18 PM
rosslato's Avatar
rosslato
just loop it around like this, then angle your spark plug boot to adjust the loop away from the header.
Old Nov 24, 2005 | 10:35 AM
jcswm's Avatar
jcswm
Vortec heads = Plenty of room
I can stick my finger between the boot and the headerpipe!!
To New Hooker Sidemount headers install spark plug wire problem need some help.
