Radiator Water
This is the back side of a water pump that we just pulled off of our '67 Jaguar E-Type. The previous owner ran tap water and coolant in the car because he believed the tap water here in San Diego was "clean enough."
The water pump was actually clogged with particles and wouldn't leak through the bearing failure holes, making us think that the pump was ok. However, we'd rev the engine and could see the pulley moving up and down in time to the revving of the engine. This also caused a "pinging" noise, which was the impeller rubbing up against the housing.
RUN DISTILLED WATER!!! And flush your system frequently to prevent breakdown, corrosion, and clogging.
(This has been a Public Service Announcement brought to you by the Committee of Keeping Corvettes Running.
)BTW, like the previous posts said, distilled water can be found at your local supermarkets, WalMart, KMart, Sears Essentials, Target, etc., usually located in the beverage aisle.
W. C. Fields
I never drink water; that is the stuff that rusts pipes.
W. C. Fields
I never drink water. I'm afraid it will become habit-forming.
W. C. Fields
W. C. Fields
W. C. Fields
W. C. Fields
NEVER
's
