curiosity - "stingray"
Old Nov 27, 2005 | 03:19 AM
ilkhan's Avatar
ilkhan
Default curiosity - "stingray"
If you were tasked to come up with a corvette "stingray" model, which only has to be realistic and profitable, what would you do? Explain options, engines, limitations, whether the Z06 remains or not, etc.
edit: Not really looking for 1-2 line replies, please put some thought into this. If its in depth enough to be a goal for the C7, so be it (mine is)
Old Nov 27, 2005 | 03:36 AM
penniman's Avatar
penniman
Cruising
i think it would be a z51 coupe w/mn6 but with a cam change to the engine a la ls6. maybe only a small horsepower increase but make the engine peakier so that at the track it would be slightly but consistantly faster that a standard z51 coupe. But the big thing would be the badge "Stingray" on the front fender instead of Z06
Old Nov 27, 2005 | 04:24 AM
ilkhan's Avatar
ilkhan
The Stingray would replace the Z06. For a base price jump of $5k over the coupe, the stingray would get the current Z06 widebody, brakes, suspension, wheels, and tires.
Engines built at the handbuilt plant, but with a twist. Historically, the stingrays (their generations anyway) had a wide veriety of possible engine choices, which made it a major descision as to which to buy. A similar concept would be used here.
For $5k, the engine would get replaced by the LZ1. Move to a 4.125 bore, 3.25" stroke (5.7L). Titanium/sodium filled valves, titanium rods, forged crank, and forged pistons wold help decrease rotating mass to achieve a 7500 redline, 7600rpm fuel cutoff. An aggressive cam to take advantage of this revving nature pushes power to the 560 range, but sacrifices low end (not peak) torque to get it. Redlines with horsepower just tapering off.
For $8k, the engine would bet replaced by the LZ2. A shortened stroke would decrease displacement to 5.3L (4.00"x3.20"). Forged pistons, crank, and rods would increase strength. A centrifugal blower (sourced from vortec or procharger) would push power to 525/500, with a nice sloping torque curve.
For $11k, the engine gets replaced by the LZ3. This is basically a LS7 of today. With this option, you get pretty close to the Z06 of today, but with a set of roof options [later].
For $15k, you get the LZ4, take a LS7, start by adding forged pistons, then add a turbo to either side of the block, intercoolers in the front bay, and 200HP over the LS2.
For all stingray models you get your choice off aluminum frame/hardtop (cost+10%), steel frame/targa roof panel ($0), steel frame/T-top ($0) or Al frame/targa/T-top with an extra 50lb of structure (cost+20%). Vert is also available as steel frame only, and costs $10k extra (approx coupe->vert cost as is)
Most other options are priced higher than the coupe/vert versions, but nothing is packaged, everything is individual.
Stingray only options: Dry sump available for an extra $1k, lighter weight wheels/tires for an extra cost, etc. R8C is included in the cost of the stingray, while the new $1080 R9D makes available a second (earlier) date to watch your engine being assembled at the engine plant.
[edit] For $1500 the widebody kit gets converted to carbon fiber. For $2k, the kit gets modified like this. For $3k, you get the new kit with carbon fiber
Last edited by ilkhan; Nov 27, 2005 at 05:19 AM. Reason: little changes/addressed CJs comment
Old Nov 27, 2005 | 05:00 AM
Corvette Junkie's Avatar
Corvette Junkie
Night Race Blue 427
From: Muncie, Indiana ...... Can I buy an amplifier on time ... I ani't got no money now but I'll pay you before I die
Originally Posted by ilkhan
For all stingray models you get your choice off aluminum frame hardtop (cost+10%), targa roof panel ($0), T-top ($0) or Al frame + targa/T-top with an extra 50lb of structure (cost+20%). Vert is also available as steel frame only, and costs $10k extra (approx coupe->vert cost as is)
Why would they want to add weight as lose strength by using aluminum instead of the magnesium they use now?
Old Nov 27, 2005 | 05:17 AM
ilkhan's Avatar
ilkhan
frame being the aluminum frame used in the Z06, not the magnesium framed roof panel
Old Nov 27, 2005 | 09:26 AM
KALAWAY's Avatar
KALAWAY
If you were tasked to come up with a corvette "stingray" model. Not really looking for 1-2 line replies, please put some thought into this. If its in depth enough to be a goal for the C7, so be it (mine is)
Hey Ilkhan, you're not a GM engineer are you, looking to cash in the Forum's imagination and expertise?
Old Nov 27, 2005 | 09:52 AM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
The “stingray” was never a separate model. There is nothing special is to way they called it a stingray. So why should they start now. Will people please get over the fact that the word stingray or sting ray means absolutely nothing .
Old Nov 27, 2005 | 02:32 PM
ilkhan's Avatar
ilkhan
I know, but it has that perception in the eyes of the public.
Its like they couldn't do what I had above, use it as a trim level essentially, or an option branch.
? I hope that was sarcastic. I asked for longer replies because the description I had was in-depth (see above) and didn't want it to be the only one.
edit: ? why did this get moved to C3 gen when Im asking about ideas for the C6?
Old Nov 27, 2005 | 05:11 PM
Nowhere Man
ya it makes them look stupid
Old Nov 27, 2005 | 06:38 PM
BigBlockk's Avatar
BigBlockk
Where did you originally post it?
BigBlockk
Later.....
Old Nov 27, 2005 | 07:01 PM
Nowhere Man
you spelled it "stingray" on word so you mean 69-76 cars. If you said "sting ray" two words it would have went to the C2 section. and I would be happy if I never heard anyone refer to old covettes as sting rays.
Old Nov 27, 2005 | 07:09 PM
69stingray's Avatar
69stingray
Thats easy.
An ultra-light version of the Z06 or and lightweight light version of the Z06 with a supercharger (Blue Devil?)
Radio delete option, lightweight aftermarket seats, no fancy ride/traction control. ALL body panels carbon fiber, etc.
To curiosity - "stingray"
