Rocker panel on side
Old Nov 27, 2005 | 12:49 PM
RequiemNightmare's Avatar
RequiemNightmare
Default Rocker panel on side
I've seen some of you guys on this forum with chromed up rocker panels on the sides of your vettes, did you just remove all the paint and polish it up? Or is it easier just to paint em?
Old Nov 27, 2005 | 12:51 PM
Yellow73SB's Avatar
Yellow73SB
St. Jude Donor '07
Old Nov 27, 2005 | 01:22 PM
wnjlt1's Avatar
wnjlt1
here is a previous post
http://forums.corvetteforum.com/show....php?t=1158611
Old Nov 27, 2005 | 01:29 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
I started with a die grinder with some of those 3M disc to knock off the anodizing and take out the heavy road rash on my rockers. Then I started hand sanding with water and 200 grit. Then I made my way up to around 1500 grit. After I was finished with this I polished them with bench grider and some red rouge. Looks great.
Old Nov 27, 2005 | 05:42 PM
RequiemNightmare
How much work would it be just to repaint them the black that they came, just some stripping and repainting?
Old Nov 27, 2005 | 10:06 PM
Z-man's Avatar
Z-man
They came the way Eddie has his looking...the only paint was the black stripe.
To Rocker panel on side
