Starter question
Old Nov 28, 2005 | 09:06 AM
markbett's Avatar
markbett
Default Starter question
Are all starters for small blocks the same?? I know this sounds stupid, but I bought my '69 with a new (1500 miles) factory 350 engine, or so I was told (no paperwork to confirm). The starter just went the other day and I was going to switch to a high performance gear reduction starter. Can I get anything that fits a GM small block, or do I need to get more specifics? Anybody have an opinion (I'm sure you do) on which starter I should use??
Old Nov 28, 2005 | 10:41 AM
stingr69's Avatar
stingr69
The starter nose cone must match the diameter of the flywheel. If the 2 bolts on the old starter are inline with each other, you have the small flywheel. If the 2 bolt holes are diagonal, then you have a large flywheel. I would guess you have a diagonal pattern for the larger flywheel but that is only a guess.
None of that matters if you are buying an aftermarket starter that has both sets of holes.
Hope this helps.
-Mark.
