How much does a C3 weigh?
Old Nov 30, 2005 | 10:09 AM
johnnya's Avatar
johnnya
Default How much does a C3 weigh?
I searched everywere and cannot find nothing, im sure this has been brought up before......
thanks guys
Old Nov 30, 2005 | 10:20 AM
Z-man's Avatar
Z-man
Anywhere from 3200 - 3700 lb or so...
http://idavette.net/facts/70.htm
Old Nov 30, 2005 | 10:23 AM
fauxrs2's Avatar
fauxrs2
Each year is a little different.. getting heavier up to 1978 (78 was the heaviest C3 IIRC) the 78 had a curb weight of something like 3557#
CURB WEIGHT - The calculated weight of a vehicle with standard equipment only as designed with the additional weight load of oils, lubes, coolants, and fuel, all filled to capacity.
check this link.... http://www.vettefinders.com/78registry/specframe.htm
Model Curb Weight 3557
Optional Equipment weights
A/C = 63 L-48 engine
A/C =67 L-82 Engine
Power Windows = 8
Gymkhana = 7
Radio AM/FM = 13
Radio Stereo = 13
AM/FM stereo/tape = 15
Tilt/Tele = 2
Heavy duty Battery = 5
L-82 V8 = 20
Auto trans = 34
A car with the highlighted options would have a curb weight of 3715#
Old Nov 30, 2005 | 10:29 AM
Ganey's Avatar
Ganey
Depends on options.
Some nos. here:
http://www.corvetteforum.net/c3/vette73/S_WEIGHT.htm
Old Nov 30, 2005 | 11:15 AM
my72vette454's Avatar
my72vette454
My big block twin turbo vette weighs right at 3400 with a full tank of gas and no driver
Old Nov 30, 2005 | 05:44 PM
Maine Vette's Avatar
Maine Vette
That depends, do you have titanium rotors?
Old Nov 30, 2005 | 08:22 PM
fl_rider's Avatar
fl_rider
Default Ooooooooooooooooohhhhhhhh!!!!!
The mere mention of TITANIUM makes me shiver.
Old Nov 30, 2005 | 09:42 PM
carl a's Avatar
carl a
Old Nov 30, 2005 | 10:07 PM
rihwoods's Avatar
rihwoods
[QUOTE=fauxrs2]Each year is a little different.. getting heavier up to 1978 (78 was the heaviest C3 IIRC) the 78 had a curb weight of something like 3557#
Good site...L-82 engine weight is interesting...
Rich
Old Nov 30, 2005 | 11:55 PM
SharkPilot's Avatar
SharkPilot
My '69 weighed 3390 many years ago when it still had the TH400, steel wheels, the original iron intake and stock exhaust.
The '68 weighed in at 3230 IIRC. Big-block with headers and a scatter shield and virtually no other options.
These weights were on two different public scales and years apart but I don't know how much difference that would make.
Old Dec 1, 2005 | 04:48 AM
early shark's Avatar
early shark
'71 LS-6 coupe....certified weight at scales 3340lbs. This is the weight with virtually no fuel showing in tank.
Don't know what the weight of the tilt/tele column option or the rear window defogger option weights are, or addtional weight of radio being the optional stereo version.
Shipping weight shows 3202lbs with 3 gal of fuel. Curb weight is 3292 includes full tank of fuel (18 gals)
Add to this 10lbs for PB, 28lbs for PS, 11lbs for radio, plus LS-6 with HD trans 82lbs.
Therefore shipping weight without fuel is 3184 with standard equipment. Add 18 gallons of fuel 108lbs, ps 28lbs, pb 10lbs, radio 11lbs,
LS-6 & HD trans (M22) 82lbs comes to 3300lbs.
My car certified at 3340lbs, and has these options as well, tilt/tele, rear window defog, stereo radio. So assume these make up for the 40lbs as well as maybe a gal of fuel.
By the way, car still rides on 1971 dated original Goodyear F 70x15 rwl tires.
Old Dec 1, 2005 | 05:19 AM
Graemeinvette's Avatar
Graemeinvette
Old Dec 1, 2005 | 07:05 AM
johnnya's Avatar
johnnya
awsome, thanks guys.
Im tryin to see how much HP im gonna need to run 11's
And with a 6 speed im sure I can get great mileage!
Old Dec 1, 2005 | 09:16 AM
Corz's Avatar
Corz
Cruise-In IV Veteran
mine's 3100lbs
Old Dec 1, 2005 | 10:08 AM
rihwoods's Avatar
rihwoods
Going to put my 69 on scale pads to find out total weight and front/rear ratio....
Old Dec 1, 2005 | 10:53 AM
68/70Vette's Avatar
68/70Vette
I believe that a 1968 Convertible, without AC, no power accessories, and a manual transmission was the lightest C3 made. I don't have my documentation handy right now, but I think the shipping weight was about 3100 pounds. Is it possible that the 68 Convertible weighs less than a 05 Z6? If that's so, then perhaps the 68 Vert weighs less than any C3, C4, or C5!
Old Dec 1, 2005 | 08:25 PM
ETM's Avatar
ETM
I think the weight peaked in about 78 or 79.In 1980 they started to shed some Lbs.Still around 3300.
To How much does a C3 weigh?
