Garage Door Insulation
Old Dec 3, 2005 | 12:36 PM
Red 69's Avatar
Red 69
Default Garage Door Insulation
With so many great minds at work here, I am posting my problem seeking suggestions. I have a metal double overhead garage door that is uninsulated, which makes for huge temp swings inside the garage and transmits all fabrication noise outside. A neighbor brought the noise to my attention the other day. The homes are very close and it is a deed restricted community, so I don't want to make waves. Before adding Frost King and Reflectix to the inner skin of the door as a solution; I thought to ask if anyone else has solved this problem?
Old Dec 3, 2005 | 12:57 PM
Suncountry's Avatar
Suncountry
Building supply stores sell that pink foam board in different thickness that they glue to foundations. Just cut it and slip it into the panels. It will give you some good insulating properties and should cut down on the noise transmission.
Old Dec 3, 2005 | 01:02 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
I know this doesn't help much now but when I had my new door installed I bought the door that came insulated and panelled on the inside. The inside is finished like the out side and I hope does a good job of dousing my busted knuckle cuss words.
Old Dec 3, 2005 | 01:23 PM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
That's the best you could do. Put as thick a foam as you can fit. I put some siding underlament, just 1/4 inch stuff on the inside of my wood garage door and it helped a bunch...
Old Dec 3, 2005 | 02:42 PM
rosslato's Avatar
rosslato
i did the above 1st then attached a layer of reflectix over that and taped the seams. made a huge improvement over road noise(live on a main rd and 6 barking dogs) and keeping the cold out
Old Dec 3, 2005 | 03:29 PM
gq82's Avatar
gq82
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Except I used white insulating board, glued it on and taped any seams. It really cut down on the cold the door transmitted into the garage.
Don't know about noise as that's not why I installed it.
Old Dec 3, 2005 | 03:43 PM
comp's Avatar
comp
the silver
Old Dec 3, 2005 | 04:15 PM
Puckboy's Avatar
Puckboy
Use the pink board and let them drive you car
Old Dec 3, 2005 | 04:46 PM
Red 69's Avatar
Red 69
Thanks for all the suggestions. I had considered the foam board, but a sales person at Lowe's told me it wouldn't help with the noise. It seemed to me if it were glued to the door it would have to quiet my hammering etc. Maybe I will follow rossalto's lead and add the reflectix with tape. This sounds like a good idea for fire prevention; I think that foam is flammable and around my welder and torch a potential hazard. I knew you guys could help me finalize a plan, thanks!
Old Dec 3, 2005 | 11:02 PM
Scottys78's Avatar
Scottys78
Old Dec 4, 2005 | 04:41 PM
Red73's Avatar
Red73
Me Too.
Old Dec 4, 2005 | 07:33 PM
Glass Act's Avatar
Glass Act
From: 406ci SB, AFR 180 Heads - 490 HP @5,600 RPM 529 lb-ft @ 4,100 RPM
Call a garage door installer in your area, they sell door blankets that attach right to the door that are sound deadners and will keep the heat in.
Old Dec 4, 2005 | 09:14 PM
DR.Jay's Avatar
DR.Jay
Originally Posted by Red73
Me Too.
Now thats a sweet looking Vette!
Old Dec 5, 2005 | 11:44 AM
LemansBlue68's Avatar
LemansBlue68
I used Cellotex foam board that has foil bonded to both sides. It had a higher R factor than the pink or white styrofoam. I think it is R9 vs. R3.
I used liquid nails to bond the panels to the door. It worked great. I could feel the garage warming up as I was gluing on the last few panels. No kidding. My garage is generally at least 10' warmer inside than out, even on very cold days and just from the warmth of the heat coming through the walls of the house. Of course insulating your garage doors won't do a thing if the walls and ceiling of your garage aren't insulated too. I'll be installing my overhead heater during Christmas break to make the garage nice and toasty.
Old Dec 5, 2005 | 01:11 PM
427V8's Avatar
427V8
C6 the C5 of tomorrow
Go to the local home improvement store, I bet they have a retrofit kit. I know Menards by me does...
Old Dec 5, 2005 | 04:00 PM
Red 69's Avatar
Red 69
Lowe's sells foam inserts for the metal overhead doors they carry at $89 a 8 ft section. That foam is not fire retardant, so it is cost effective for me to buy and cut the 4x8 foot sheets they sell. I have nearly a full can of 3M spray adhesive, so I will give that a try. The foam at Lowe's has a barrier on both sides, gray on one and clear on the other. There was no foam sheets with foil at my store. By the end of the week I should have the door finished. There is plenty of cutting and gluing small pieces into the metal door pockets. It is hard for me to believe anyone would buy an uninsulated overhead door for an attached garage, but there it is.
Old Dec 5, 2005 | 04:55 PM
mrtroutjedi's Avatar
mrtroutjedi
this is what I did and it worked great
To Garage Door Insulation
Old Dec 5, 2005 | 05:32 PM
ruby76's Avatar
ruby76
From: Fairview Heights Illinois, near Saint Louis MO, STL C3 Shark
That is how builders save money around saint louis. My sister just moved here from northern iowa and she and her husband were amazed that their VERY NICE house came with uninsulated garage doors. Mine came with an insulated one, but I "saved" money on my detached garage and got an uninsulated one - which of course I'll be spending money to have insulated........
Old Dec 5, 2005 | 05:38 PM
zonie77's Avatar
zonie77
I just put up insulated doors and the insulation is similar to the foam sheets with a firm surface of vinyl. It isn't glued but was put in before the ends were capped.
I'd think any foam would work both for temperature and noise.
Old Dec 5, 2005 | 05:45 PM
skydaddy's Avatar
skydaddy
We used the insulation board with the foil on both sides and then used the metal tape to hold everything in place. While you can still hear some noise through the door - it has reduced the noise and deffinately stabilized the hot/cold swings. We got the insulation boards as thick as we could and then doubled them up and slid them in - We have a big shop door and it had fairly thick pockets to put the insulation.
