What gear ratio
Old Dec 3, 2005 | 10:06 PM
1978 Pace Car's Avatar
1978 Pace Car
Default What gear ratio
Tonight I got my car up to 80mph for the first time! When I did my tach was reading 5500 rpm. It was in the yellow line of my tach, so what gear ratio do I have guys?
Thanks guys: Gene
Old Dec 3, 2005 | 10:13 PM
76mike's Avatar
76mike
I think that I have 4.11 gears and mine isn't that bad... you're either running higher than that or you have small tires.
Old Dec 3, 2005 | 11:24 PM
supercalvin's Avatar
supercalvin
WOW, What gear was the tranny in?
Old Dec 4, 2005 | 01:13 AM
Older Than Dirt's Avatar
Older Than Dirt
If your tire diameter in height is.......
25" your rear end ratio is 5.12
26"............................. 5.32
27"............................. 5.52
Old Dec 4, 2005 | 01:54 AM
fauxrs2's Avatar
fauxrs2
Thanks guys: Gene
Well the Steepest gear available in 78 was a 3.70:1 gearset....
If you have the factory gearset then you must have insamely tiny tires...or your Tach is wrong...
Old Dec 4, 2005 | 02:04 AM
63C2splitter's Avatar
63C2splitter
CF Senile Member
St. Jude Donor '08
Something isn't right. Is it an auto or standard transmission? If an automatic, is it getting into high gear?
My 63 has a 4:11, and at 80 it tachs at about 4200. my tire height is ~27 inches.
Old Dec 4, 2005 | 07:31 AM
Glensgages's Avatar
Glensgages
When I ran a THM400 and 26" tires on my Z28, 85 MPH was approx 4800 RPM.
To accurately compute your gear ratio, we'd need to know what size (height ) your rear tires are, and what type of transmission (THM350/400, A/OD, or standard shift ) you have, and if your tach is functioning properly:
after-that, it isn't too-difficult.
Old Dec 4, 2005 | 11:43 PM
1978 Pace Car
Im having a hard time beliving it myself! I will measure my tires in the mourning! I counted the gears when my car shifts and it goes all the way up to third gear with no problem, I just dont understand why it seems so low! It doesnt seem right! Thats for sure.
Old Dec 4, 2005 | 11:46 PM
Stoge's Avatar
Stoge
I don't know anything when it comes to this stuff, but is it possible that his torque converter is messed up?
Old Dec 5, 2005 | 01:20 AM
Glensgages's Avatar
Glensgages
..... this is another possibility.
Old Dec 5, 2005 | 04:56 AM
camaroneil's Avatar
camaroneil
could it not be his speedo,
he was maybe doing 120 mph !!!!!!!!!!!!!!!!!!!!
i know my speedo is real sluggish, especially when cold,
natt
Old Dec 5, 2005 | 07:18 PM
1978 Pace Car
Ok, heres what I have for tires on the car, their P225/60 R15. And they measure at 24 3/8" tall. Whats that sound like to you guys now? Is it the tires or the the speedo, or torq converter?
Thanks guys: Gene.
Old Dec 5, 2005 | 09:47 PM
Glensgages's Avatar
Glensgages
..... you didn't even consider that the tach could-be off.....
Using a formula that I've used for years to compute RPM/MPH/tire-height/gear-ratio, here is what we know:
RPM: 5500
MPH:80
tire-height: 24.375
"assuming" a 10% slippage in the torque-converter (typical of THM350/THM400 ), this is what the calculation would be:
RPM (5500 ) x.9 (10% slippage ) x .006 (a 'factor', that includes pi ) x 1/2 tire-height (12.187, in this instance ) divided-by MPH (80, in this instance ) = GR (gear-ratio ).
5500 x .9 x .006 div/by 80 = 4.52, or close-enough to be considered 4.56 gears:
I'd still jack-up the car, spin the tires 10 revolutions while counting drive-shaft revolutions, and divide drive-shaft revolutions by 10.
Old Dec 5, 2005 | 10:01 PM
1978 Pace Car
Thank you very much!!!!!!!!!!!! That would suck if I did have gears like that in this car! But I will jack up the car this week if it doenst snow on us and do what you told me to do.
Thanks again: Gene.
Old Dec 5, 2005 | 10:13 PM
Glensgages's Avatar
Glensgages
Maybe, maybe-not..... if you DO change the gears, and you DO have .56s, I understand that they are very hard to find any-more, and may-be worth a few scheckels.....
With 4.56s, that thing oughta SCREAM off the line, if it hooks at-all, even-if it is a wimpy L-48!
..... I will jack up the car this week if it doesn't snow on us and do what you told me to do.
Put a chalk-line on the very-bottom of the drive-shaft, and a chalk-line on the inside of the wheel/tire, from the bead to the tread, at the very-bootom, as-well:
spin the tire exactly (or very-close to exactly ) 10 revolutions while counting drive-shaft revolutions (full AND partial revolutions ).
33+ revolutions would be 3.31s or 3.36s, 35+ would be 3.55s, 37+ would be 3.70/3.73, 41+ would be 4.10/4.11, 45+ would be 4.56s, etc.
To What gear ratio
